to drain or turn on the furnace mid 20's coming
Hey guys so we've already been camping in NC now we are back home in Michigan. The weather is going to get into the 20's at night for three nights. Should i drain the water sys temb and blow out the lines? Just turn the furnace on to like 40-45 and let it run at night? we did spring break with it so it is no longer winterized. Any thoughts?
No not staying in it. Just for camping every other or every third weekend. Just hate buy anti freeze and winterize the whole thing for a few days of sub freezing temps. I can dragon the low point drains and blow it out without a buying anything other than a fitting I'll need anyway. This is my second camper but my first new one so i want to keep it nice.
Isn't spring wonderful
I've pushed my luck on occasion in the fall when the temps dip into the 20's at night with no antifreeze. But to be on the safe side, would probably want to drain and blow out those lines if there was no interior heat into the 60's during the day. There is one salvation - most trailers built in the past 20 years or so have PEX feed lined rather then copper(as my long gone Kountry Aire had) and will expand a bit if some slushy ice forms - but drains and traps are still rigid ABS
All drained and blown out. Good tip on the drains I'd have forgot about them. I don't think I would have a problem but if they forcast 27 and we get a clear night and get near the teens i would be nervous about it. I'll grab some antifreeze tomorrow at lunchtime and tip some in the drains then I don't have to run the furnace. Thank you all for your replies. The wife wiuld not let me forget it if i let the brand new camper we've had for a month freeze up because i didn't want to walk out 50ft and drain things out.
Delta2142
6.4L Power Stroke Diesel
21
04-02-2013 07:34 PM
