Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Sterling 10.25 Disc Brake swap.
Old 04-20-2015, 05:33 PM
Crewcabber's Avatar
Crewcabber Crewcabber is offline
Crewcabber is starting off with a positive reputation.
I went and picked up another 10.25 sterling from a guy that bought almost all the stuff to do a disc brake swap. New e350 rotors Chevy calipers new seals and new bearings for 150.00. I found the brackets at ruff country for 50.00. Can anybody that has done this swap tell me what brake lines they used. I've read everything from dodge lines to Chevy lines to everything else. I know the calipers I have do not have the parking brake attachments. Think I might clean this axle up do the swap sell it and buy an 01-04 SD 10.50 and have the hubs machined so I have the parking brake.
__________________
The Beast cclb 4X4 460 E4OD4" LIFT 35X12.50X16 OBD1
The Red Rocket 1995 EXTRA CAB s/b 2wd 2.3
Comfort Cruiser 2001 Acura MDX Touring
Annoying Orange 1971 Safari Fiberglass buggy
1969 Chevy C20 factory A/C long bed
1933 Chevy Pickup
Old 04-20-2015, 07:25 PM
daddylee100's Avatar
daddylee100 daddylee100 is online now
daddylee100 is starting off with a positive reputation.
daddylee100
Subscribed..
__________________
Blaine
1992 F-350 Crew Cab 4 x 4 XLT 460 E4OD Dana 60 on 35s 4.10's
1981 F-150 Ranger XLT 351 4 x 4 C6 Super Cab lifted 8" on 35s 9" 3.50 - sold but not forgotten
1979 Pontiac Trans Am 6.6L
Old 04-21-2015, 11:51 AM
Crewcabber's Avatar
Bump to top
__________________
1933 Chevy Pickup
Old 04-22-2015, 07:28 AM
aj88V's Avatar
aj88V aj88V is offline
aj88V is starting off with a positive reputation.
No answers, but please post some pics as you do this swap. Thx
__________________
1989 F150 Lariat, "Bertie", 300 I6, M5OD. Working out the mechanics before the paint and body.
First Ford since selling my '72 LTD convertible. Nice to be back with family.
Old 04-22-2015, 07:38 AM
merc460 merc460 is offline
merc460 is starting off with a positive reputation.
I used mid 70 Caddy brake lines when I did mine, but then I used Caddy calipers as I wanted the park brake feature to be "legal" .
__________________
Eric
Old 04-22-2015, 08:29 AM
'89F2urd's Avatar
'89F2urd '89F2urd is offline
'89F2urd has a good reputation on FTE.'89F2urd has a good reputation on FTE.
brake line answer is easy: make your own. buy pre-fabbed lengths and bend them, or buy a roll of the nickel copper line and just buy the associated fittings. need a flaring tool of course.
__________________
'89 F2 4x4, HPKP D60, ZF5, Fixed output 1356, 351: ported/milled gt40P's, 10.5:1, 35-255-5, .060 bore, long tubes, etc.
-'02 dodge 2500 6 spd cummins, 300k miles: 545/1240 rwhp/tq-DD/tow rig
-'00 SS camaro 6 spd, NA & stock cube: 440/425 rwhp/tq-for rippin
-'84 FJ60 LC - 4bt/nv5600; 320/750 whp/tq
-'00 7.3 e350 chateau; 4x4 zf6
Old 04-22-2015, 12:48 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
For the flex hoses on the couple I have done I used front caliper to axle hoses for a 92 Dodge W250 Cummins, they don't need to be as long as they are, but the Dodge uses hardline on the axle and a short flex hose at each wheel end, with a single drop line in the middle rather than 2 long flex hoses like the front end of a Ford.
I chose the application simply because I have one of those trucks, and they have an attached mounting tab on the axle end of the hose.
__________________
96 F350 Crew Psd/5 speed,/4x4... $600 special
96 F250 XLT PSD/5 speed/4x4... Freebie!
92 W250 LE, 4x4/CTD/G360/D60/D70U
86 F250 HD 4x4, 6.9/T19/broken D44 TTB junk/10.25.
8? F100 4x4 Mild 460/T19 D60/welded 10.25/44 Boggers,
It's not what you BUY, It's what you BUILD
Old 04-22-2015, 06:24 PM
'89F2urd's Avatar
For all my flex line needs I go to a local hydraulic spot and have them fab me up some stainless braided lines. Damn near any hydraulic shop can fab you some lines for cheap.
__________________
Old 04-22-2015, 10:22 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a very good reputation on FTE.Nothing Special has a very good reputation on FTE.Nothing Special has a very good reputation on FTE.Nothing Special has a very good reputation on FTE.
Quote:
Mixed opinions on braided stainless. Often it's not DOT-approved. I guess the problem is that grit can get trapped in the braiding and then work a hole in the hose. A friend of mine watched a J**p do a multiple endo - roll when a braided stainless line blew on a failed hill climb.
What's good about it is that it doesn't bulge under pressure so your brakes work more crisply.
When I got new brake hoses for my Bronco I was send braided stainless hoses (I hadn't realized that's what they would be). But they have a clear rubber/plastic coating to keep grit out of the braids and they are DOT approved. Food for thought.
__________________
Bob
'97 F-250HD 4WD Crew Cab, 460, E4OD, 4.10:1
'71 Bronco, 302, NV3550 5 spd, Atlas 4.3:1, 4.10:1, Detroit rear, 33" BFG AT http://www.ford-trucks.com/forums/12...ospective.html
My toys: http://www.ford-trucks.com/forums/12...-jeep-etc.html
Old 04-23-2015, 10:19 AM
Crewcabber's Avatar
Thank you guys. Braided lines would be the best performance wise. I have a hose maker right down the street from my office. Nothing special those are the same lines I had on my banshee when I went wider a arms. The worked awesome. I think I'm going to run the Dodge lines like mentioned above just for the simple fact they are an off the shelf part.i really appreciate everyone's help.
__________________
1933 Chevy Pickup
Old 04-27-2015, 11:44 AM
Crewcabber's Avatar
I got the rear end out of the back of the truck finally and up on the bench. Removed the exiles hubs and backing plates. Still have to clean it up and paint it. My caliper brackets will hopefully be here in the next couple days and then I'll paint it.
__________________
1933 Chevy Pickup
Old 04-27-2015, 06:33 PM
daddylee100
Woo hoo!!!!
__________________
Blaine
Similar Threads
axle swap/disc brake conversion. tdbronco77 1987 - 1996 F150 & Larger F-Series Trucks 1 12-21-2014 08:49 AM
10.25 Sterling Disc Brake Conversion RabidJade Clutch, Transmission, Differential, Axle & Transfer Case 7 09-13-2013 12:33 PM
Rear Disc Brakes on a 1991 JDWard 1987 - 1996 F150 & Larger F-Series Trucks 15 01-21-2013 12:38 PM
SSBC ? 4ordLord 1987 - 1996 F150 & Larger F-Series Trucks 5 10-18-2012 07:58 PM
Sterling Disks NorthernDiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 24 03-25-2011 09:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
