are all lift kits the same?
I got lucky and bought a 6 inch skyjacker lift kit off a lady on Craigslist for $300 brand new in the box. The problem is its for an 88 - 96 f150.
Could I use it on a 86 bronco or is there something that changed between 87 and 88? I know f150s and broncos are the same in the front end and I think there the same on the rear end.
It's a basic kit with drop brackets and add-a-leafs
the 9" stopped around 84 with some still around on the 85's.
doesn't matter though which rear diff he has. the lift will work regardless. Does that lift you bought come with Extended radius arms or the radius arm drop brackets? You will want to get extended brake lines if you plan to wheel much.
