'79 Bronco 9-inch info
Well, my center section is blown-up. I'm trying to figure out whether I should buy a new one or have mine rebuilt. In keeping my eye out for one, I have a few questions.
Thanks
- According to the tag, it's a 3.50 gear with limited slip. Is that all the info I need?
- Are there a variety of spline counts for our trucks, or if I look for one from a 78-79 bronco, or 70's F-150 will I be ok?
- Also, are they all limited slip, or is that a rare option that will make one harder to find?
Thanks
You can count the splines but it is most likely a 31 spline,unless someone changed it out in the past. Also the limited slips arent ultra rare but they do wear out so finding a used 1 that isnt probably is a rarity. Personally I would just rebuild mine or have someone do it if I dint know how. Then you know what you have.
*70F250*
02-26-2008 10:59 AM
ford390gashog
09-21-2005 12:11 PM
