Redneck gen/alt swap
You are both correct, the alternator was about 3/16" proud when I took the pic. That has been remedied with washers at the engine mount, and the upper spacer was shaved accordingly. Also, since the rear of the alternator has a slight taper, it had a tendency to walk forward - that too has been remedied. No vibration at all, very smooth. It's a true one-wire 80 amp alternator.
Very cool, I use the 3 wire GM alternators all the time, backhoes, tractors, etc..
For those who want to do this cheap get a 1975 camaro alternator for about $30 from autozone..wire it up like this. Simple.
I have not had good luck with the one wire units as they needed to be spun up to work, the 3 wire works great at idle.
I can't take any credit for the bracket except for the cleaning, painting, and notching for the screws. That's the 1950 OEM Ford generator bracket. Note it in the first pic.
