help. does my 460 need a valley pan or not?
Found my oil leak, and I also found out in order to fix my antifreeze leak I need to remove the Intake. .
Autoparts gave me a valley pan set. My gasket I put on a few weeks ago was just the heads and the ends. No pan. Can I use the pan? Does it matter? Use the gasket set and jus leave out the pan?
Help. Trying to fix it today
Use the pan, always..
I've fixed a few coolant leaks on the intake and its always from over or under torquing the intake bolts. I usually don't use the gaskets just put a heavy amount of high-temp gasket maker on the ends of the intake where the gaskets would be. Let it set up then follow the proper torque sequence, then re torque after the motor gets up to temp and then cooled back down.
I know the long block came w a gasket set that didn't use the pan. So that's what's in it now. And when I spoke w the owner of our local machine shop he said with the aftermarket intake, to not use the pan.
With conflicting opinions, I guess I need to contact Wieland intakes.
FYI that leak is on the water pump bypass tube, which can't be removed without taking the intake or pump off.
My oil leak appears to be on the rubber front seal, originally I thought it was the distributor.
PapaBearYuma
04-14-2017 04:33 PM
hasteranger
11-30-2012 08:38 PM
Danny Stroup
18
01-24-2010 08:14 PM
Ds7776
03-03-2004 04:01 PM
purplegoat
36
11-13-2002 01:13 AM
