common chassis and drivetrain upgrades?
Lots of good info here. If wanting to beef up the drivetrain, it sounds like u-joints are the first priority. Then axles? In thinking more about my question and the replies above, it looks like one would take different paths if doing serious off-roading versus wanting to put power on the pavement. I'm more in the later camp. Like advertised max power specs on aftermarket transmissions, anybody have specs for the clutch, NP435, transfer case, etc.?
Why bother with 1350s if you're going to spend the money?
I went to 1410s, mainly because that's what th F450e trans I'm running had a yoke for, I'm using the drive line out of a 2002 SD truck. My truck is a complete mutt.
Decide how you want to use the truck then you can compile a list of modifications.
For me the best upgrade I've done is Hydroboost, everyone else I know that has done it says the same thing and once my new shop is set up 2 other FTE members are getting Hydroboost installed.
It's a good point to define the end-state and then choose upgrades consistent with getting there. My questions also come from being a mechanical engineer in a former life and thinking about strength of components and materials. Even today I noticed a newer model Dodge 2500 with a massive-looking rear axle that dwarfs my D60. Got me to thinking whether this was needed to handle the engine power, towing, or more for looks and customer appeal? Lots of the TV shows also seem to install upgrades that seem overkill or mismatched with remaining components.
Ill toss some pennies
Starting simple
Oil change
Spark plugs, wires, cap and button
Transmission fluid
U-joints
Brakes
Axle fluid
Previous owner electrical problems
Carb rebuild
Fuel tank inspection
Rubber fuel lines
Then the toys
Lockers
Big tires
CD player
Paint
Intake/Carb upgrade
Hei dizzy
Cam
Headers
Winch
I agree shows like trucks and others are overkill with unlimited money with more of a cool factor than reality
Starting simple
Oil change
Transmission fluid
U-joints
Brakes
Axle fluid
Carb rebuild
Rubber fuel lines
Then the toys
Lockers
Big tires
CD player
Paint
Intake/Carb upgrade
Hei dizzy
Cam
Headers
Winch
Stephen Dazey
93
02-20-2016 02:59 PM
USArmyTaterness
03-06-2012 10:23 AM
