Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
E4od lock up problems
Old 04-19-2015, 09:28 AM
droppedf100's Avatar
droppedf100 droppedf100 is offline
droppedf100 is starting off with a positive reputation.
96 f150 351/e4od. Friday I drove it to the track and once I was on the highway I noticed it revving too high. So turns out the converter isnt locking up. I have a 3 way switch set up to either be stock/unlocked/locked and if I put it into the lock position it locks right up but won't lock up in the stock position. Any ideas what could be wrong?
Old 04-19-2015, 10:00 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
That indicates that the PCM isn't calling for it to lock. It probably is one or more sensors are sending data indicating to not lock. It could be a bad bulb in one of the three brake lights, too.
__________________
Mark
Former Ford Automatic Transmission Engineer 1988 - 2007
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Old 04-19-2015, 10:31 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud ofFORDF250HDXLT has much to be proud of
im with Mark,i like to tackle and rule out the easy things first.another quicky;
or a bad brake switch (BOO) on the brake pedal.
edit,and don;t take for granted your custom lock up switch isn't prone to failure either.may want to bypass this next,hooking up the (what it is,the purple wire with yellow tracer iirrc?) back up directly to rule this out.
__________________
Log Truck: '93 F-Super Duty (F450) XLT 1st Gen Navistar 444ci IDI Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 5:13, Dually, 16' Dump & Auto Crane.
Chip Truck: '93 F250HD XLT 4x4 1st Gen Navistar 444ci IDI Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, E40D, 3.55, Dually, 9' Dump & Plow.
Old 04-19-2015, 11:27 AM
I forgot to mention I bypassed the switch and it made no difference. How would I know if the brake switch is bad? 3rd brake light works I'll try to check the rear brake lights now
Old 04-20-2015, 06:22 AM
Ok I checked the brake lights and they are all working as they should. Also cycled the hazard switch as I read somewhere that is an issue as well. Also noticed when the switch is in the stock position it won't lock up but the od light doesn't flash or throw a trans code. But when I force it to lock up even on the highway it throws a 743 code. So it seems the pcm doesn't want the converter to lock for some reason. I'm lost.
Similar Threads
E4OD TCC Engagement Blurry94 Clutch, Transmission, Differential, Axle & Transfer Case 1 01-20-2015 08:36 PM
auto hubs wont stay locked cattlerancher Super Duty & Heavy Duty 5 11-27-2014 08:43 PM
No start with key.......lock cylinder? rc31080 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 07-21-2014 01:05 PM
Does a 90 E350 w 460 & E4od have locking TC? boxdin 1987 - 1996 F150 & Larger F-Series Trucks 3 05-02-2014 08:08 AM
Transmission not received. Christopher Rohland 1987 - 1996 F150 & Larger F-Series Trucks 14 08-31-2013 06:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
