new oil cooler results
First I would like to thank everybody here and I am glad this site is exists for people like me. I am not sure where I read the recommendation for diesel tech Ron, but his hour and a half video on how to replace the oil cooler gave me the confidence I could do the job myself. And I did it in a day and a half, not too bad for my first time. I am really happy with the results. I followed all of Ron's advice and everything went smoothly. My oil temps were running about 11 degrees over the coolant before the replacement and now is around 6-7. I had purchased a delete kit for the EGR cooler but to my surprise a stealth delete had already been performed. The blue spring upgrade had not be done yet so now that's done too.
I am glad this job is complete. I do wonder how long the new oil cooler will last. I don't have an external filter on the coolant. Also I have been running aftermarket wix oil filter too (I will change that soonest).
Thoughts?
Thoughts?
Thanks for the replies. It feels really good. I jumped into the diesel world with both feet and (eyes closed). It was a very steep learning curve starting with the first oil change. I was discouraged at first, but I am getting to know the issues and how to fix them. My confidence in the truck is growing.
jsm180,
I purchased the truck in October. I did not know the stealth delete was done. I did the VC9 flush the oil temps jumped. pulling my 5000# travel trailer I was seeing 217 degrees. I was between jobs so now was the time...and I am learning every day. Thanks for the input, I hope I don't have to do it again.
I would recommend putting a coolant filter on your truck or start saving now for a new oil cooler in two yrs time. New Ford oil coolers come with a two yr warranty because of the known failure rate. Besides that mine stopped up after 1.5yrs even with monitoring and back flushing oil cooler once a month due to fouling. Put the coolant filter on there and immediately noticed a difference in condition of coolant not to mention the trash that was in filter after cutting it open.
All Motorcraft parts come with a 2 year warranty, it's not because they have a 2 year failure rate
My truck went 10 years and 150,000 miles on the original oil cooler and I am over 3 years on the replacement with another 30,000 miles with no coolant filter.
Im seeing a broad range of results with my 6.0. It runs anywhere from 4*-17* difference. Granted when the coolant is cooling down. So is the oil temp. While I am cruising it will hang out 185*/~195*. But when I started climbing a big pass here in Montana it seen that oil temp hit 221 degrees and the coolant temps were ~205.
With loads and grades all other variables nothing is certain.
Josh
If I can get 100k out of the oil cooler, I will call that good. I might put an external coolant filter on, but I would rather put an upgraded alternator first. I just need a place to put that amp and subwoofer from my old truck...
On a side note, I broke the tab on the oil temp, turbo solenoid, and lost the little plastic insert for the ICP connector. I have had problems with all three connections now...that seems to be the extent of what went wrong.
