Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
SPONSORED BY:
Click HereAdvertisement
What is this? And a few codes
Old 04-18-2015, 07:06 PM
goodhews goodhews is offline
goodhews is starting off with a positive reputation.
Had this truck a few years now, and it has always had a slight miss/hesitation and maybe a few codes. The timing chain skipped a tooth and the truck was down for about a year. I have 4 other trucks, so it wasn't a big deal. I finally had time to put a new oil pump, chains, guides, tensioners, phasers etc. The truck actually runs very well and quiet. But, now misses far more than I remember it doing.
When driving in town constant at 25-30 mph occasionally it will loose power for a brief moment(<1 second) and then be fine, the security light on the dash turns on for a few seconds.
It drives at 55-65 just fine, unless I am going up a hill or something else increasing the load.
2004 5.4 3v 2wd
CEL-
P0453 (fuel tank pressure issue)
P0351 (ignition coil a primary/secondary circuit malfunction)
P0356 (ignition coil f primary/secondary circuit malfunction)
The coil packs are new, and I have injectors on order. But, any thoughts or ideas would be much appreciated.
Also found this thing on the back of the motor, it connects to the fuel rail on the drivers side. No idea where it should go. I looked on my other trucks. But my other 04-4wd has a box by the battery it connects to, but mine doesn't have any of that stuff. And my 08 doesn't have anything like this at all.
And a pix of the truck in question. Thanks again!
Old 04-18-2015, 11:58 PM
turbodave89 turbodave89 is offline
turbodave89 is starting off with a positive reputation.
That's The Vacuum line for the front diff, uses engine vacuum to engage the hubs when shifted to 4 hi/lo your truck is 2wd so its capped
Old 04-19-2015, 12:28 AM
Thank you sir! That's what I had figured. But also wondered why Ford would go to the trouble of fitting that line onto 2wd trucks and just leaving it hanging.
Similar Threads
Help Identifying rubber. Aarons54f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-27-2014 08:09 PM
Ford Carlisle pictures pintoplumber 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-10-2014 01:59 PM
Turnin 8' service body 93 F250 to An enclosed 9 footer PIC Heavy jesse24spd Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-20-2014 11:14 PM
Visual upgrades - what do you recommend? the_auto_tech Super Duty & Heavy Duty 127 01-07-2014 06:09 AM
My two sons became Ford truck owners today! the_auto_tech 6.0L Power Stroke Diesel 18 12-26-2013 03:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
