Broncos II HELP!!
Old 04-18-2015, 03:37 PM
southpaw776's Avatar
southpaw776
southpaw776 is offline
Broncos II HELP!!
I am looking at getting a 1984 Ford Broncos II. can anyone tell me how good the engine is at handling steep hills (paved) ? What kind of lift and tires can I put on it that will off road well and not negatively affect the performance?
Old 04-19-2015, 12:18 PM
reddog99's Avatar
reddog99
reddog99 is offline
It's been a long time since I've owned it, but my old '84 Ranger with a 2.8 L. V-6 was fairly unimpressive in the power department. If you install taller tires, you are effectively changing the overall gear ratio and will have to compensate with lower gears in the differentials. Also, taller tires will make the brakes less powerful, something that these older trucks can ill afford. Their brakes are a bit weak to start with.
Old 04-19-2015, 12:20 PM
southpaw776
I had a feeling the engine was a bit of a dud. Thanks
Old 04-19-2015, 05:56 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Unless you are willing to trash out the stock carb, distributor, and computer and emissions controls and Duraspark convert it, then you can add goodies like a hi-po cam, Offenhauser 4bbl manifold, holley 390 4v carb and edlebrock headers.
Then you can leave the guys with 4.0s in the dust.
Old 04-19-2015, 06:35 PM
southpaw776
I am not looking for speed so much as torque. Where can I find info on a duraspark conversion
Old 04-19-2015, 07:28 PM
Old93junk's Avatar
Old93junk
The Ranger Station has the best write up on Durasparking the 2.8 I have ever seen......VERY simple.
Old 04-19-2015, 07:48 PM
southpaw776
Thanks a lot.
85BRONCOXLT
1978 - 1996 Big Bronco
11-27-2012 10:07 PM
customsport
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
12-23-2010 01:47 PM
sdkoz
12-12-2004 01:20 PM
xyz1406a1
17
11-04-2004 05:47 PM
fordmudrunner2020
07-07-2003 01:35 PM
Quick Reply: Broncos II HELP!!
