Need Advice for my 53 F250 - Ford Truck Enthusiasts Forums
Old 04-18-2015, 03:04 PM
Agrajag Agrajag is offline
Agrajag is starting off with a positive reputation.
I just want to get this truck going and I was wondering what advice the experienced folk here could give me.
The flathead that was in it needs to be overhauled and that's just an expensive project all the way around. The body itself is in pretty good shape, a little bit of rust here and there, but overall great, and the frame is just a rusty frame. I'll take care of all that, but my first goal is just to get it on the road and enjoy it.
Here's the crazy thing, I actually want to keep the unassisted manual steering, and the brakes too. I don't care if it's not geared to go faster than 50mph either. I don't have to be able to take it on the highway to be happy with my truck. I would also absolutely prefer to keep it manual transmission as well.
What motor can anyone advise that I drop in there to keep this thing pretty much basic? I really don't care about power, I'm not looking for a race car, but rather an old truck, so a six or four cylinder with decent torque would be fine for me.
Old 04-18-2015, 03:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Well, a thorough rebuild on a flat V8 costs $2500 +/-. It's within a couple hundred of what it costs on a SBF or SBC, if you compare apples to apples. No adapters, new engine supports, re-wiring, new exhaust, etc. makes it overall cheaper. I wouldn't dismiss the possibility of going that way.
Old 04-18-2015, 03:55 PM
Steve49841 Steve49841 is offline
Steve49841 is starting off with a positive reputation.
You and I have the same truck and almost the same situation except in my case the previous owner had already installed a 302 4 speed and rewired everything for 12 volts. It sounds like you are just trying to make a driver out of your truck so if there's anyway to use the motor you have (or replace it with a similar motor) you will be ahead of the game. There is no such thing as dropping, stuffing, sticking or slipping a later model motor into your truck, it takes a lot of time and money.
Old 04-19-2015, 12:15 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Not sure but Maybe you could get a straight 6 of the same era. It may mate up to your current transmission. There's always someone pulling a good running 6 to modernize their power train. If your lucky you might even be able to get the clutch assemly and bellhousing too.
Old 04-21-2015, 02:36 PM
Thanks for the advice, I appreciate it.
1998 F150 XL 4wd V6 Auto doublecanister 1997 - 2003 F150 2 12-26-2016 11:11 AM
Hesitant First Time Buyer Guido95 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 10-05-2016 03:01 PM
Need advice on missing components on truck xdstockx 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 45 04-03-2014 07:27 PM
Column Replacement, 1989 Ford E-350 Van TombstoneLizard Brakes, Steering, Suspension, Tires, & Wheels 0 07-19-2011 06:55 AM
Eddie Bauer vs Limited, what's the difference? guiri Excursion - King of SUVs 20 02-11-2007 04:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
