ZF5 Install
ZF5 Install
I just came back from picking up a ZF5 tranny (Craigslist buy) that I will be installing in my 1960 F100 4x4. Can anyone give me some direction on where to buy a hydralic clutch set up? I'll need a pedal, master cylinder, pretty much the works. I'll be putting the tranny behind a 300 six.
I have an extra set of pedals. pm me if you think you can use them.
I bet you could make an adapter bracket to use the master cylinder from the transmission donor year, then a hose would be compatible to the slave.
FWIW 91 and earlier ZF uses a speed cable. 92 and later doesn't.
I had a ZF behind a 300 and loved it. With 31 inch tall tires the 4.10 gears were just right. My 300 was warmed up a little. Had a comp 260 cam (looses some low end, not much torque below 1600-1800rpm) An Offy C intake with 390 Holley and efi twin exhaust. All pretty good but don't do an aftermarket intake without building a heater on the bottom. I never got better than 13-14 mpg.
black66
03-22-2004 12:21 AM
Eddie
06-07-2001 08:10 AM
TallPaul
10-16-2000 10:37 AM
