E99 7.3 checkup
E99 7.3 checkup
Hey guys,
I've got and early 99 F250 and the engine is coming out next week to do an oil pan, injectors, and glow plugs. I want to know if there is anything else I should be replacing or checking while this is all apart? I'm not sure if it matters but the injectors are stage 1.5's from FFD everything else is OEM parts.
Up pipes and manifolds. The pipes are spendyour Riffraff Diesel Bellowed Up-pipe Kit 94-Early 99 - Riffraff Diesel Performance but a one time purchase. If your manifolds are leaking about $60 at a machine shop will make them flat again. Not impossible to do with the engine installed but SOOOOOOOOOOOOOO much easier with it out.
When I had a 7.3 I frequented thedieselstop.com. Lot of experienced guys there willing to help out. It's where I first saw posts about Ford transmissions from former Ford transmission engineer Mark Kovalsky, who also posts on these pages.
If your 7.3 is stock, you may want to consider a bigger downpipe, another intake, a better turbo boot ( I used RiffRaff's) and possibly a tuner to wake it up. Had good luck with my DP Tuner.
Thanks to both of you!!!
Bigblockboy
08-21-2016 12:07 PM
fordboy2
15
02-22-2009 04:10 PM
Wellcraft
08-31-2004 08:38 AM
