Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
5.4 with morning time grumble
Old 04-17-2015, 09:09 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
I'm assuming I might have a coil going but I'm not sure. Yesterday morning and this morning I started my truck and it was fine, I backed out the driveway again truck was fine. I put it into D and pull forward it was fine till I hit about 1300rpm, then it felt trike the truck was stumbling, I went a little faster to 1500/1600rpm and it stopped, as soon as I slowed up and then hit the go pedal it started again at around 1300rpm and stayed till 1600rpm and then it went away. So this is twice now two days in a row this has happened the exact way and only in the morning and goes away with no problems. I hooked up my SCT X3 and there are no codes and when it stumbles I have no lights come up. Any ideas on what I should do?
iPhone from IB AutoGroup
__________________
2004 F-350, XLT, SC, SB, FX4, 5.4, 4R100 w/ .472 line mod valve & TransGo HD2 reprogramming kit, 4.30 gears w/ Detroit locker, zoo dad mod w/ STOCK intake, Gibson stainless headers, SPD y-pipe, 51509 cat, Borla 3" exhaust, 1" rear AAL, dually upper and lower overload spring, 08 diff cover, ProComp 22210 springs, more.....
Old 04-17-2015, 09:37 AM
r2millers's Avatar
r2millers r2millers is offline
r2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to behold
Sounds that way to me. Not sure how many miles on your plugs but they need to be changed after 100k. Your cop boots start to crack and "leak" pulses out to the plug hole walls, giving you a random misfire for that cylinder.
If I drive my 5.4 hard, it will pull a code which sure helps to identify the exact cylinder.
You might just order boots and change out, whether with or without plugs.
__________________
Bob and better half
As my brother reminds me regularly... "Life is not a spectator sport."
2007 F-250, PSD, SW, CC, LB, 2 WD, 85k, coolant filter, DashBoss, 1999 Expedition 5.4 322k plus, 32' CrossRoads CrossTerrain 5th wheel Toy Hauler, 24' Chaparral Villain lll 598 ci
Old 04-17-2015, 11:12 AM
Bought the truck brand new, I install motorcraft plugs ever 30k and COP boots ever 40ish. I have 133k now and just did new plugs and COP boots this September
__________________
Old 04-19-2015, 04:39 PM
Ok two days with no issues...what the heck is going on with my truck?
__________________
Old 04-19-2015, 06:14 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant futureBigpipes 35 has a brilliant future
Mine will do that once in a while if we get a lot of rain, I say drive it until it throws a code then you will know the offending cylinder
__________________
Chris aka FTEMaB 3
2003 F250 fx4 cc short box. 5.4 , 4.30 gears, flowmaster 50 , spd Y pipe , eagle alloys , 285/70/17 nitto terra grapplers, SCT X3 tuned , warn manual hubs, 6.0 trans cooler mod
2006 Keystone sprinter copper canyon
2000 f150 4x4 work truck 4.6 AKA Martha
http://i1206.photobucket.com/albums/...es35/truck.jpg
Old 04-19-2015, 08:25 PM
r2millers's Avatar
Check to see that you don't have an intake manifold leak, allowing coolant into the plug hole to help ground out the COP randomly.
__________________
Bob and better half
Old 04-20-2015, 07:49 PM
Quote:
It didn't rain the first day but the second morning it was pouring when it happened, and since then nothing so I'll keep an eye on it I suppose
__________________
Old 04-22-2015, 12:55 AM
Psyclopse's Avatar
Psyclopse Psyclopse is offline
Psyclopse has a good reputation on FTE.Psyclopse has a good reputation on FTE.Psyclopse has a good reputation on FTE.
Double check all of your COP-to-harness connections. I did plugs/boots/COPs not long ago and things were fine for quite a while. Then I started experiencing issues similar to yours. When I investigated, I found that I didn't have two of the COP connectors fully seated. Been problem free ever since.
__________________
Joey
2000 Excursion Limited V10
1999 F-250 Super Duty V8
Pic: My '99 & my dad's F-350 Crew
Old 04-22-2015, 08:45 AM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is online now
Bently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant futureBently_Coop has a brilliant future
O-rings on the COP boots may help. See link below. Otherwise maybe time to clean the IACV.
http://www.ford-trucks.com/forums/11...s-the-fix.html
__________________
99 F250 CCSB V10 4x4 Lots of money into it.
Old 04-22-2015, 11:25 AM
00F350XL's Avatar
00F350XL 00F350XL is offline
00F350XL is starting off with a positive reputation.
Ruby Shirlee RUBY_R1 iamrubyshirlee
Kind of a similar issue that im investigating now
Old 04-22-2015, 11:26 AM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
That doesn't mean your new parts are not malfunctioning....
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR Gen2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, EA 270A Alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, Novi2k blower, MM suspension parts, etc
Hope & A Prayer Motorsports
Old 04-22-2015, 11:54 AM
Thanks Bently I'll check this out later today
__________________
Similar Threads
Improved turbo questions Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 05-16-2014 12:14 AM
6.8 V-10 stumbles on cold start 12valveEx Excursion - King of SUVs 1 05-15-2014 02:40 PM
Got some problems... Need help. strokersace 1994.5 - 1997 7.3L Power Stroke Diesel 20 01-13-2011 03:07 PM
Wierd thing happend! Run Away Diesel! adambomb 6.0L Power Stroke Diesel 50 02-15-2008 09:31 AM
hmmm... another cps issue? kbeefy 1999 - 2003 7.3L Power Stroke Diesel 3 09-08-2006 11:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
