So my tail lights and license plate lights are not working. The head lights work also my gauge cluster lights are not working.does anybody know which fuese I should check. Or any other thoughs what it might be?
Thanks guys
Check ground at back and all connectors, you may habpve a dead short taking that fuse out. All the salt and grunt get up there and corrodes everything.
Some times they just get tired and quit like any other component.
The old glass type with the zinc element inside I can agree with you. But the modern blade style ones, no they don't wear out. They blow because of a heavier draw than what they're rated for.
where did you find the fuse? I have searched the internet and don’t have an owners manual.
His fuse may not be in the same location as yours since you did not post what engine you have.
You can get your owner information by going to the appropriate Ford web site (motorcraftservice.com/ownerinformation) using the link below, or I could post an owners manual for you if you post your engine year.
