1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2014 F350 brake job question
Old 04-16-2015, 08:50 PM
builttoughf350's Avatar
builttoughf350
builttoughf350 is offline
I have a 2014 F350 4X4 which needs the front brakes done already, ( 38,000 hard towing miles )
Do I need to remove the front 4x4 hubs to get the front rotors off ?
Or just hammer them off of there...
Thanks !
Old 04-17-2015, 05:54 AM
CollinsCD's Avatar
CollinsCD
CollinsCD is offline
No need to remove hubs but are you sure you need rotors too? The OEM rotors a great and should last for many miles.
Old 04-17-2015, 05:58 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
I've got 96k on my factory front rotors. They are still good.
Removing the front hubs is a good idea, as long as you're in that area. Clean them and give them a very light lube.
Old 04-17-2015, 07:06 AM
builttoughf350
My truck pulls an equipment trailer daily, plus snow plowing in the winter.
My front brakes had a squeal when stopping for a while, and just as I'd gotten to the point of "I'll throw some new pads in there" before I knew it the squeal sounds turned into a GRIND
One of the pads wore through and gouged the crap out of the right rotor.
I'm the kind of guy that will just spend a bit more and slap new ones in there. Problem is, none were in stock at that point ! Both stores said they were a week out. This was a few weeks ago.
So I just slapped new pads in until I could get around to doing the entire job. Napa had a 20% discount going on parts so I got front and rear heavy duty pads, plus their top of the line rotors for about $380.
I'm totally ok with this. The truck will be towing more weight this season than it did last season ( new machine ) and I just want to not have to worry about the brakes for a while ! The truck needs to be on the road daily.
Old 04-17-2015, 07:33 AM
CollinsCD's Avatar
CollinsCD
Well gouging a rotor is a whole other story. Searching on this site shows good results with the OEM rotors and pads.
Old 04-17-2015, 02:09 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Apply anti seize to the rear hub surface of the rotors they will come off a whole lot easier next time. Nothing goes back together in my garage without a liberal coating(except for items which need loctite of course).
Old 04-17-2015, 05:22 PM
senix's Avatar
senix
senix is offline
Received 1,398 Likes on 995 Posts
You might need to spray some PB Blaster or WD 40 around the hubs and lug nut studs to get the rotors off.
I have found that using a brass punch and hitting that in a few places between the studs on the surface area of the rotor will help to knock it loose so you can do the switch.
Old 04-17-2015, 05:28 PM
clem1226's Avatar
clem1226
clem1226 is offline
a couple raps with an air chisel will usually get it done.
Old 04-18-2015, 05:49 PM
builttoughf350
I got them off with the five pound hammer.
new front rotors and pads are in, rear pads are in. all seems great so far, looking forward to when they are properly seated / broken in. Took about 1.75-2 hours to gather all my tools, set everything up, do all the work with a few distractions / phone calls in there.
thanks for the help !
Old 04-19-2015, 11:12 AM
eberlestock's Avatar
eberlestock
eberlestock is offline
Great advice. I do this as well
JethroF250
06-08-2010 04:43 PM
erik_bishop
09-07-2007 05:56 PM
dagren99
13
01-06-2007 09:25 AM
earl964
06-11-2006 12:35 PM
00250diesel
17
11-18-2005 09:12 PM
Quick Reply: 2014 F350 brake job question
