Frame Alignment Specs
I know a guy who's good at pulling frames out, usually by chaining one end to the tree and pulling with a bobcat, but that's up in MN, probably out of your range quite a bit. Sounds crude, and it is, but I've seen multiple newer cars that he's pulled that had no alignment issues, body panels fit together well, etc. What I'd recommend is to keep looking. The shapes of these frames is much less complicated, so one would think a simple fix... I would say a stripped down frame should only be $100-200 at most, but I'm probably too cheap. Won't you run into title issues with a new frame though? unless you were cutting/welding..?
Novak just got back to me, they can't (or won't) tackle it. Contacted James Phillips in Arkansas and he has a frame but one of the crossmembers is cut in half. Thank GOD BigWin56 has one. Guess I'll be picking up a different frame at the SuperNationals. Sure wish I owned my shop. I'd be sinking tie downs in the floor and trying to straighten it myself.
Heading to Super Nationals to pick up a different frame. My plan was to just swap everything from ole 56 on to the different frame because I like the stance.
Ole 56
I got looking at the front spring shackles and springs. I'm sure it's original but I'm not sure the springs nor shackles are suppose to look like this. Any thoughts? I am afraid to put new springs on because I got a feeling it'll significantly change the ride height.
I do have a set of mono 5" drop front springs I guess I could try.
Ole 56
#30
Well will wonders never cease! Was driving over to the welding parts store and saw a little Bodyshop. Decided it couldn't hurt and stopped with the pictures of the 56. The guy took a look and said NO PROBLEM! So I dropped it off. He called today and said it's done! I'll snap some pictures of it when I pick it up tomorrow.
