360/390 exhaust manifold cracked
Old 04-16-2015, 05:47 PM
Rasputin53's Avatar
Rasputin53
Rasputin53 is offline
<insert expletive here>
Taking the parts down to the machine shop and I remembered to grab the exhaust manifolds to get them resurfaced. And then I see the stripe of death. Long, straight hairline crack on the passenger side manifold, dead center vertical. Should I just weld this pig up or am I hosed?
Old 04-16-2015, 07:46 PM
Binkowski's Avatar
Binkowski
Binkowski is offline
Headers
Use it as an excuse to buy a good set of headers.
Old 04-16-2015, 08:10 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
IIRC, RockAuto sells replacements for around $100.
LMC does too..!
I'd be heading to the JY for a low-buck replacement... but yes, I concur with ^^^Big Bad Bink cuz it's the gearhead thing to do.
Old 04-17-2015, 07:19 AM
GLR's Avatar
GLR
GLR is offline
PM sent I might have some.
Old 04-17-2015, 11:32 AM
Rasputin53's Avatar
Rasputin53
These look pretty good (I mean cheap )
http://www.summitracing.com/parts/bi...view/make/ford
George, I'll look at the number tonight.
Old 04-17-2015, 11:53 AM
GLR's Avatar
GLR
GLR is offline
Isn't there a starter problem with the long tubes?
Old 04-17-2015, 12:50 PM
XLTF100's Avatar
XLTF100
XLTF100 is offline
I can ship you a pair for dirt cheap, if you like?
Old 04-17-2015, 06:09 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Two different FE left exhaust manifolds.
C5TZ-9431-A = Left Exhaust Manifold: 1965/67 F100/350 352 & 1973/74 F100 360/390 - Use with heat riser valve.
C8TZ-9431-B = Left Exhaust Manifold: 1968/72 F100/350 360/390 - 1973/76 F250/350 360/390 - 1975/76 F100/150 360/390.
D0TZ-9430-A (replaced C5TZ-9430-A) = Right Exhaust Manifold: 1965/67 F100/350 352 & 1968/76 F100/350 360/390.
All 3 of these manifolds are available NOS
Old 04-17-2015, 06:56 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is online now
2X Bink. Headers and Stage 8 brand header bolts. With these you'll never have a blown header gasket.
Rusty_Old_F250
Ford Truck Parts for Sale
02-04-2016 11:30 AM
SeaBeeCm1
10-02-2011 06:50 PM
F6001986
03-18-2006 02:19 PM
Karm
10-10-2004 10:59 PM
bigtymer77
07-27-2004 05:38 PM
Quick Reply: 360/390 exhaust manifold cracked
