391 governor carb and distributor help
I swapped the hd330 for a 391 into my 1977 f600 dump truck and started it today. The distributor that came in the 391 just has a vacuum advance, no governor. The distributor an carb off the 330 has a governor. I had to use the carb on the 391 and when I started it, it would idle good but would not accelerate. Is there something I can bypass on the carb? I don't want to put the governor distributor off the 330 in it if I don't have to. Is there any way to make this carb work with a regular distributor?
Is there a reason you don't want the governed distributor.
We ran several 391's back in the day and the only one we had problems out of had a stuck governor weight in the dist that would allow the engine to over rev. That engine broke 2 pistons, pulled the little end out of one rod and broke a crank, all at different times so in a two year period I had that engine down 4 times.
After finding the dist problem and fixing it the engine ran for several years.
3900 rpm was the governed speed for a 391 with the heavy truck pistons they used.
1954wrecker
06-20-2018 10:35 PM
Tienfan789
13
10-24-2016 07:35 PM
Ford391
05-29-2004 04:06 PM
