2003 4.0 rev limiter at 3000 rpm?
ok so that's what if feels like, in park at idle it sounds great, starts great no codes. IF you floor it it will not go over 3000 rpms in park, it feels like it has hit a rev limiter. I have 60psi fuel pressure at idle and at 3000 rpm.
When driving down the road I won't go over 55 mph and drives normal if you keep it under 3000 rpm, if you give it more gas it falls on its face?
ac is not working (clutch not engaging)I don't know if that's related or not.
Any Ideas?
we did just swap the motor the truck is a 2003 2wd drive. motor came out of an 2002 4wd. we are running the 2wd harness, computer egr delete etc.
Any Ideas?
xrayman
09-03-2004 04:40 PM
