76' F100 w/ 351M swap w/ 95' 302 ENGINE MOUNT HELP
Old 04-15-2015, 12:50 PM
I_Am_Ozymandias's Avatar
I_Am_Ozymandias
I_Am_Ozymandias is offline
Question 76' F100 w/ 351M swap w/ 95' 302 ENGINE MOUNT HELP
My 76' F100 currently has a 351m w C6 auto transmission in it, and I am putting in a 95' 302 from a F150. {Donor truck, and the recipient pictured side by side below.}
Will I need new mounts to put the 1995 302 in my 76? or... I could I simply cut the mounts off the 1995 donor truck, and weld them into my 76? I have an Oxy/Acet rig, and a MIG welder on hand if I needed it. WHats the best way to go here?
Also, looking for any information/expertise anyone has on the Transmission Cross Member as well to mount a 95' 4R70W / 302 into the 76'.
Old 04-15-2015, 09:08 PM
Conanski's Avatar
Conanski
Conanski is offline
I have no idea on the engine mounts but you have all the parts sitting there and the tools too so I would think you could make it work.
Old 05-16-2015, 07:23 PM
GreyScar's Avatar
GreyScar
GreyScar is offline
Just curious why would you pull a 351m for a 302?
Old 05-16-2015, 11:13 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,578 Likes on 1,288 Posts
Stock for stock the '95 302 out powers the 351m from any year.
However, a '76 should still be running either a 302 or a 360/390 as OEM. Wasn't the 351M/400 intro'd in trucks in '77?
smokey
07-11-2012 10:03 AM
finneys98xj
08-31-2010 05:21 PM
roy123
Engine Swaps
01-26-2007 08:57 PM
Bill W
01-26-2007 08:23 AM
jbutaford
08-26-2002 08:21 PM
Quick Reply: 76' F100 w/ 351M swap w/ 95' 302 ENGINE MOUNT HELP
