03 no start
03 no start
03 F-250 5.4
Standard Transmission
Thought my battery was no good , so changed it.
Didn't help it just kinda bumps the motor but doesn't turn over.
Thought it must be my starter then , bought a $200 starter and changed it , still doing the same thing.
It did start after changing the starter but wont now.
Any ideas?
Nuetral safety switch?
Any ideas?
A neutral safety switch should keep the starter from doing anything, not "bumping" it. Do you have a way to check for voltage? You could have a high resistance in a battery cable as one thought. You could check voltage when cranking, maybe doing a voltage drop test if warranted, make sure you have a start signal to the starter from the ignition switch. Just some thoughts.
So I couldn't find anything that looked like a relay to jump across?
I unplugged that wire with the yellow on it close to the battery.
I jumped it to the battery and truck started?
So Im trying to figure out iof the problem is between the battery and the ignition or the battery and the starter?
Any guess's?
Any guess's?
Darn it. The next thing I would check is the clutch switch. Since you have manual transmission, that means you must depress your clutch pedal to start it for safety reason. That switch would be the next thing to check. I don't know where it would be, but it has to be above the clutch pedal.
Don't guess, use your voltmeter and see where the voltage is going. A quick field kind of test is crank while headlights are on and see if they stay bright, or dim out all the way.
http://www.aa1car.com/library/voltage_drop_testing.htm
gaffmedic
08-13-2007 06:48 PM
69mustang
08-02-2004 03:42 PM
