Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Sign in using an external account
Register Forgot Password?
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Would Foam Insulation Panels Be Okay?
Old 04-14-2015, 10:19 PM
Clem's Cousin Clem's Cousin is offline
Clem's Cousin is starting off with a positive reputation.
I'm thinking of insulating my older van with 3/4" or 1" foam insulation panels with a foil face. This would be glued in place with some 3M spray adhesive. Would this be a good way to go or would it be likely to hold moisture behind it and cause rust?
Old 04-15-2015, 08:54 PM
vettex2's Avatar
vettex2 vettex2 is offline
vettex2 is starting off with a positive reputation.
it seems to be the prefered way . I think they use thinner stuff though ,
__________________
2004 E250 4.6 V8
NASCAR Winston Weekly Racing Series Track Championship Crew Member (Dirt Track) Chevy
NASCAR Dodge Weekly Racing Series Track Championship Crew Member (Pavement) Dodge
NASCAR Whelen All American Weekly Series Track Championship Crew Member (Pavement) Ford
NASCAR Whelen All American Weekly Series California State Championship Crew Member (Pavement) Ford
Old 04-15-2015, 11:55 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
Use thinner the thicker will not conform to the panel walls. Maybe a couple of layers of 1/4-3/8 no more than 1/2 inch to use. Thicker might work on headliner and floor as they tend to be flatter
Old 04-16-2015, 05:55 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
General rule of thumb is foam is preferred although there are other materials well suited for this with a little work foam can be cut to conform to the cavities in which it would eventually be installed.
The first consideration will be deciding how you'll cover the side walls and ceilings in order to determine the cavity depth which in turn would dictate the foam panel thickness used. Roof/ceiling would be no more than 1" thick if you're using the factory roof bows or supports as the "nailing surface" for final trim. Sidewalls could use from 1" to 2" depending where along the horizontal plane insulation and covering will be applied.
If there's a "trick" to having thick foam panels conform to the curves its simply cutting them into short sections that lay almost flat against the sheet metal. If you're familiar with woodworking this would resemble vaulted ceilings or other glue-ups where the finished result is a curved surface.
Sadly I don't have any illustrations to demonstrate this. For my own insulation of a work/cargo van I used a combination of radiant barrier insulation along with traditional fiberglass unfaced bats, the Johns-Manville white no-itch version. Works well enough to be comfy-cozy with my after market rear heater----tee shirt only warm even in winter.
Old 04-16-2015, 06:51 PM
maples01's Avatar
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
facebook.com/TheCrip Maples01
I put 2" thick boards in the walls of my 73 Econoline, left a 1" gap for air at the bottom of my walls, to allow it to breath, just slit it with a utility knife for relief cuts to allow it to conform to the wall.
__________________
My wheelchair has yet to stop me from wrenching on my vans.
Old 04-16-2015, 09:05 PM
I have some cabinetry woodworking experience, so I think I know what techniques you guys are referring to.
The insulation panels I was looking at at the big-box home improvement store were already "pre-bent". Someone stacked the panels incorrectly making them all bowed enough to only require a few relief cuts where the body curves the most! Hard to beat the convenience of pre-bent.
I guess I'm concerned about the lack of air circulation between the insulation and the body. I think I'll just Por-15 the whole inside before I install anything.
Old 04-17-2015, 05:56 AM
JWA's Avatar
JWA JWA is offline
Before you go all crazy with POR-15'ing the whole interior consider this.....
Adding insulation and then perhaps interior finish trim paneling the need to protect body sheet metal from condensation disappears because after such improvements it no longer collects on the sheet metal. Since the finished interior is now the first surface condensation would reach if it were to collect anywhere it would be there.
Because of this moisture isn't trapped in insulated cavities its not necessary going to extraordinary measures to stop something that doesn't happen.
Old 04-21-2015, 05:50 PM
mos68x mos68x is offline
mos68x is starting off with a positive reputation.
If you're gonna use the thicker foam, then you could cut it all the way through for the relief cuts, but I would just use a box knive and cut at 3/4 of the way through it so that you can make it "flexible"
Similar Threads
IDI Van Guys... Foil vs Non-Foil Doghouse Insulation genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 05-02-2015 10:46 PM
Holes Rusted Thru Old Van Roof Clem's Cousin Paint & Bodywork 4 03-06-2015 10:59 AM
Hood insulation kit orich 1967 - 1972 F-100 & Larger F-Series Trucks 8 12-31-2014 11:24 PM
insulation on hose in 84 f250 FilmCarp Cooling, Heating, Ventilation & A/C 1 09-01-2014 09:37 AM
Cab insulation 351Cleveland C4 1967 - 1972 F-100 & Larger F-Series Trucks 29 05-05-2014 10:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
