Ordering a BPD oil cooler tomorrow!
I had BPD cooler installed a couple months ago after second oil cooler plugged up. Removing the ac condensor made it easier to install. Also installed their remote oil filter kit. Very happy with the new system. Also got the cold weather kit. Expensive but don't worry about high oil temps anymore. Alwaysed maintained coolant system and had a filter too. It still plugged up. Good luck with the install the directions are very good and their cust service also very helpful.
You are, or course, RIGHT.
But "NORMAL" cooling system maintenance shouldn't have to include aggressive chemical/distilled water flushing and oil cooler replacements, etc.
My previous truck, a 1994 6.5L diesel Suburban, bought new and owned by me for more than 20 years, got (in my mind) normal cooling system maintenance.
I replaced the coolant twice in 210,000 miles during that 20+ years.
I think you're right.
I did my first change at 60,000 miles (from factory fill) .......That might have been (a little late) around the 5-7 year point......and I switched it to DEXCOOL.
Then I flushed/replaced it again at about the 14 year point at around 150,000-160,000.....
The coolant was clean and clear.
I sold it in JUL of 2014 at around 210,000. It was ready for a change and I told the new owner that he needed to do a flush/fill.
Knowing what I know now and owning a 6.0L CornBinder, I don't think I'll let it go that long!!
BPD makes a bigger cooler and you should order it. When pulling our large toy hauler threw the desert In the summer your oil temp can really climb. I mean like 250 degree's. Way to hot. If your not towing it's fine. They want $600.oo to upgrade the cooler only. Rip off. Going after market on the cooler.
So, Bonanza35, You commemorating the series Bonanza for 35 years in reruns?
Or are you flying around in one?
Cheers,
Rick
I used to fly a C-model. Every model was a great airplane!! Wig-wagging itself through the air!(the Baron did it too so it wasn't just a V-tail thing!)
It was 1962 P model. Really liked the way it flew with the engine upgrade. Use to go to the EAA fly in's every year and camp out. Been to all four corners of the US with it and then some, loved the plane.
Chet
Well guys, I finished up the BPD oil cooler install Saturday and my truck is at a local shop getting the AC system recharged right now. The install was actually not bad at all. The hardest part was getting the transmission cooler out so I could put the lowering brackets on. Everything else was a breeze! Now my oil temps are staying lower than my coolant temps by an average of about 7-10 degrees. Well worth the money IMO!
#29
You mentioned you were going to attempt the install without opening up the A/C......I am assuming you thought against it?
#30
Glad the install went well!!
Did you go with the BPD remote filter and vernitherm (oil t-stat)?
AND did you get the HD cooler?
Has anyone info on doing the install keeping the OEM filter?
