Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
7.3L died on side of road...
Old 04-14-2015, 05:13 PM
twom7 twom7 is offline
twom7 is starting off with a positive reputation.
My 2002 F250 7.3L died on side of road yesterday, so I had a position cam sensor in the truck and I changed it out and it still would not start. I pull it into a church and I go back this morning and I change out the fuel filter and it starts after the engine is cold all night. I drive it 15 miles towards my house and it dies again three times before I can get it home. It seems to die after it has warmed up. It also dies because the engine fails to remain at idle. I know others have most likely had this problem before. Is there some kind of an idle switch that I need to check?? The RPM gauge drops down and the regains or jumps back up?? Any pointers on what to check are much appreciated. Thanks in advance.
Old 04-14-2015, 05:45 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud ofPitcrw6 has much to be proud of
Did you ck your oil level? What kind of cps did you put in, OEM or aftermarket? Whats your fuel level at? Could be the solenoid on the IPR but before we go that far ck your oil. Did you get a eng light?
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu is a splendid one to beholdPikachu is a splendid one to beholdPikachu is a splendid one to beholdPikachu is a splendid one to beholdPikachu is a splendid one to beholdPikachu is a splendid one to beholdPikachu is a splendid one to behold
That sounds to me like an IPR (injection pressure regulator) problem. Check to make sure the nut spacer and solenoid are in place and secure. If they are, and it cuts out again when hot, you can try pouring cold water over the solenoid. If it goes back to running ok, the solenoid is probably on its way out. Unfortunately, the solenoid isn't available separately, so if that turns out to be the problem you'll need to buy an IPR.
Old 04-14-2015, 09:18 PM
The check engine light did come on. The oil level is almost full on the dipstick. The CPS is an OEM that I got took off another ford 7.3L and I carry it in my glove box. I will pull up a youtube video on an IPR because this might be the problem. Oh, fuel is 3/4 full. Thanks for the replys.
Old 04-15-2015, 07:56 AM
I disconnected the IPR this morning after the engine sat all night and the engine was cold, but it still will not start this morning. So, still not sure whether it is my IPR. Any additional feedback is much appreciated.
Old 04-15-2015, 08:12 AM
Pitcrw6's Avatar
If you disconnected the IPR then it won't start. Did you mean ICP?
Old 04-15-2015, 08:17 AM
I disconnected the IPR which is down in the valley behind and below the fuel bowl. The IPR has a wire connector going to it which I disconnected. I will look up the ICP, but I have not disconnected the ICP to my knowledge.
Old 04-15-2015, 08:32 AM
I looked up the ICP and I have not disconnected it. I will disconnect it and see what happens.
Old 04-15-2015, 08:35 AM
Pitcrw6's Avatar
Well it sure won't start with the IPR disconnected so plug that back in. The ICP is on the drivers side head toward the front of the head. look for oil in the plug and connector. If it starts, leave it unplugged and see if the eng dies again.
Old 04-15-2015, 11:49 AM
Ok I unplugged the ICP and it still will not start. I may have to drive 75 niles to get a friends testing equipment to try to see if it is throwing any codes. I am not readily figuring this one out. Thanks.
Old 04-15-2015, 11:51 AM
There was oil on the end of the ICP and the connector wires, and I have had some kind of small oil leak for a few months on this truck.
Old 04-15-2015, 06:44 PM
Pitcrw6's Avatar
You need to replace the ICP. Now, not saying that's the cause of your no start but it needs replaced. You need to get a scan tool hooked up so we can see what your ICP is and IPR duty cycle is.
Old 04-15-2015, 07:13 PM
Ok good deal. I will change out the ICP tomorrow, and I will borrow a friends scan tool and check out the IPR. I will let you know. Many thanks in advance for the replys.
Similar Threads
6.4 revs by itself to the max for 10sec then dies 7.3stroker2 6.4L Power Stroke Diesel 12 03-04-2015 10:28 PM
7.3l dies while driving csmartin Super Duty & Heavy Duty 3 02-09-2015 08:24 PM
7.3 Power Stroke No Power Rough Idle Ckesey Super Duty & Heavy Duty 27 03-24-2014 04:52 PM
Work truck dies LaCount Enterprises 1999 - 2003 7.3L Power Stroke Diesel 8 03-19-2014 06:31 PM
broken down on the side of the road..... JNG6 1999 - 2003 7.3L Power Stroke Diesel 22 12-19-2013 05:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
