Ford 8.8 woes
Ford 8.8 woes
I have been having a hard time getting my truck back on the road. I have a 91 f150 4x4 with a 4.9. It is an 8.8 rear with 3.08 gears. I had a leak from the right rear axle seal that I didn't know about which starved the diff for oil and caused all sorts of havoc. The ring gear and pinion gear were both razor sharp. The biggest issue I discovered is that the left side carrier bearing had spun on the carrier. I went to the junkyard and got a new carrier with the gears and bearings. I swapped everything into my housing and everything seems good until I snug the left side cap. As soon as I snug up the cap on the left side the diff locks up and will not turn. If I loosen the cap, it turns free as can be. I really need to get my truck back on the road. Any ideas would be greatly appreciated.
I'm guessing you replace the r&p and just slapped it in there? If you did or didn't doesn't matter at this point as you changed the carrier, whenever you go digging into a diff you need to set the gears back up, if you changed the r&p you need to set the pinion depth to ring gear and ring gear engagement to pinion, if you just changed the carrier you need to reshim the carrier as right now it's too close to the pinion. Your best bet as you need special tools and bearing pullers is go to a junkyard and buy a complete diff and put it into your truck, u bolts are cheap and an improperly setup diff will eat itself with in minutes or grenade and setting up gears for the first time will take you hours to do it right.
http://fordperformanceracingparts.co...htM-4209-8.pdf
I've been using these instructions as a guideline to get this this thing back together. I also got a Yukon gear master install kit. I have a few torque wrenches and I borrowed a dial indicator from work. As it turns out, the shims were all wrong and I also had the bearing caps installed on the wrong sides. I have the shims sorted out and I have the backlash set to .010. I am having some problems decoding the paint on the gears. If there are any gurus who can decode the marks for me, that would be amazing.
Thor'sHammer
11-15-2014 01:50 PM
A1C DiMaggio
19
04-10-2010 07:03 PM
painintheneck
09-28-2007 11:41 AM
FordGP
12-08-2003 07:15 PM
