4x4 no low range
Old 04-13-2015, 12:46 PM
connork's Avatar
connork
connork is offline
4x4 no low range
On my 99 f250 with 6 speed manual and electronic shift...I can't get low range with the switch. Put in new switch, still no low range.
I read on this forum that to test the safety switches you can jump across 2 relay terminals and see if it goes in. So I did, went in just fine.
How do I determine which safety switch is not working?!?
Old 04-13-2015, 08:10 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
Bump to the top.
Old 04-13-2015, 08:19 PM
Baatzy's Avatar
Baatzy
Baatzy is offline
Just a thought, are you below 3mph with your foot on the brake and the clutch pushed in when you try to shift to 4LO?
Baatzy
Old 04-13-2015, 08:39 PM
connork's Avatar
connork
connork is offline
Yes...and the clutch and brake both disengage the cruise control...so what else could be the problem?
Old 04-13-2015, 09:43 PM
Baatzy's Avatar
Baatzy
Baatzy is offline
I take it the truck shifts from 2(HI) to 4HI without an issue?
Old 04-14-2015, 06:10 AM
connork's Avatar
connork
connork is offline
Correct...2 hi to 4 hi shifts just fine. Getting to 4 low works too if I bypass all the switches
Old 04-14-2015, 09:53 AM
Baatzy's Avatar
Baatzy
Baatzy is offline
Hmm, ok, interesting, do you have any way to pull codes? I am at a loss for right now.
Baatzy
Old 04-14-2015, 10:01 AM
connork's Avatar
connork
connork is offline
Yea I got a code scanner. Not showing any codes.
Let me get this straight..to get into 4 low I have to have my foot on the brake and the clutch, truck in neutral, and be at a stop...?
I think my switches are working because the 4x4 switch is brand new, the brake, clutch, and slipping the truck into neutral all disengage the cruise control..
Only thing is my speedometer don't work. Reads zero at any speed...but my odometer and cruise work just fine...
Any way to bypass all safety switches??
Old 04-14-2015, 10:19 AM
Baatzy's Avatar
Baatzy
Baatzy is offline
Kind of, to go into 4 low both the clutch and brake must be depressed and you must be moving less than 5km/h (3mph). On a manual it is not required to be in "neutral".
It does seem that all of your switches are working, but it seems like your speed input may be the one causing the issue. Can you watch the vehicle speed from the OBDII port?
The best we can really do for bypassing all the safety switches is to jump across the relays like you mentioned doing earlier.
Baatzy
Old 04-14-2015, 10:37 AM
Baatzy's Avatar
Baatzy
Baatzy is offline
From another thread, complements of cleatus12r.....
Easy test for the wiring coming up........
It takes a test light (with an incandescent bulb) and nothing more.
1. Remove the cover from the bottom of the auxiliary relay block.
2. Connect the ground lead of the test light to ground.
3. Check for B+ at the two green wires on BOTH relays (Terminals 86 and 87) as they should have power at all times.
4. Touch the test light probe to terminal 85 on either relay. That relay should click and you should hear the motor try to do something. Try the other one.
5. If nothing at all happens, then you have a relay problem (but you've already switched them out I think). If the relay clicks and the motor doesn't move or groan, then there's an issue between the relay and the motor or an issue between the relays and G100. The ground issue is easily checked by putting the test light clamp on the positive battery terminal and checking to see if it lights up on terminal 87a of each relay connector terminal (with the relay unplugged).
If everything works with the test light method, then you need to look upstream to the 4WD module. The 2Hi/4Hi doesn't care what the vehicle is doing (IE, vehicle speed, brake switch state, et al). If your relays do something with the test light, you need to look toward the control side, not the relay/motor side.
The test Cody gave us above proves out everything on the power side of the 4x4 system. I am guessing your method was slightly different than the one above, but it yielded the same results. Add to that the fact that you can shift into and out of 4HI proves out both your hi to low relay and low to high relay.
This, along with the fact that your speedometer doesn't work makes me think you have an issue on your control side, specifically with the speed input part.
Baatzy
Old 04-14-2015, 10:46 AM
connork's Avatar
connork
connork is offline
What do you mean by control side? Could it be the GEM module? That seems pretty pricey.
Not sure how to troubleshoot from there besides swapping out parts..
Old 04-14-2015, 12:57 PM
Baatzy's Avatar
Baatzy
Baatzy is offline
The control side is all of the inputs, such as brake pedal position switch, clutch pedal position switch, 4x4 switch, transfer case range input, and vehicle speed. It sounds like everything but your vehicle speed input have been verified as working.
It could be your GEM or it could be your vehicle speed input.
I will send you the troubleshooting manual for the '99.
Baatzy
Old 04-26-2015, 07:21 AM
jetdoc's Avatar
jetdoc
jetdoc is offline
Any luck with this? My late 99 has a similar problem.
Old 04-26-2015, 01:15 PM
connork's Avatar
connork
connork is offline
Well..not sure yet. Went through the troubleshooting process...GEM does not read clutch switch engaging. Haven't looked into it further than that yet until I can find a wiring diagram or trace wires.
So it's either gem or clutch switch..
Also speedo don't work, it has a wiper code(they work) and a brake switch code...so do they all point to gem or what?
That's where I'm stuck
Old 04-26-2015, 04:08 PM
jetdoc's Avatar
jetdoc
jetdoc is offline
Do we even have a GEM on a 99???
dogerbrown1
1999 to 2016 Super Duty
15
01-23-2024 07:18 PM
randybobandy
09-25-2014 09:42 PM
Jbru167
01-04-2010 11:36 AM
Sand_Man
11-28-2009 04:52 PM
cwb
07-06-2003 08:13 PM
Quick Reply: 4x4 no low range
