1991 F150 clutch wont disengage after replacement
Old 04-13-2015, 11:12 AM
zack987's Avatar
zack987
zack987 is offline
I have a 1991 Ford F150 i bought. Told the transmission was shot, long story short, found out it was just a bad clutch. Pulled the transmission, replaced the clutch, pressure plate, and throwout bearing. Put everything back together, now i cant get the clutch to fully disengage. Had good pressure prior to replacement of the clutch, still has some pressure. just doesn't have enough to disengage the clutch. pulled the inspection cover, and verified the slave is moving. Anyone have any ideas as to whats causing this issue? I cant tell you how frusterated i am with this thing
Old 04-13-2015, 11:13 AM
zack987's Avatar
zack987
zack987 is offline
Also, it has the 5-speed m5od-r2 transmission
Old 04-13-2015, 11:42 AM
stuart1's Avatar
stuart1
stuart1 is offline
Is the TOB same as what was removed and is the disc in correct?
Old 04-13-2015, 11:50 AM
zack987's Avatar
zack987
zack987 is offline
Throw out bearing and clutch both looked to be the same. Bought them as a kit together
Old 04-13-2015, 12:20 PM
stuart1's Avatar
stuart1
stuart1 is offline
Yes BUT. Did you install the clutch disc the right way? Not bassackwards?
Old 04-13-2015, 12:34 PM
zack987's Avatar
zack987
zack987 is offline
Should have been installed the right way. and not backwords.
Old 04-13-2015, 01:10 PM
stuart1's Avatar
stuart1
stuart1 is offline
Should have and has been.
Old 04-13-2015, 01:16 PM
zack987's Avatar
zack987
zack987 is offline
I did not personally install the clutch. i took the old one out, and reassembled and bolted everything back up. A friend installed the clutch, who has done clutch replacements before. I'll have to ask him about it. Any other things that could be wrong though?
Old 04-13-2015, 01:31 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
Have you bled the clutch hydraulics?
Old 04-13-2015, 05:20 PM
stuart1's Avatar
stuart1
stuart1 is offline
My next question.
Old 04-13-2015, 06:24 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
1 of two reasons.....
1. Clutch pressure plate springs have hung up or failed
2) TO bearing failed and is dragging on the shaft
that is also assuming everything else is working properly....
Old 04-14-2015, 08:46 AM
zack987's Avatar
zack987
zack987 is offline
Ive been trying to bleed the hydraulics, but i have no idea if their fully bled or not. like i said, i do have pressure, and you can see it moving through the inspection cover, but the pedal has play before it starts to get pressure. Both the throwout bearing, and the pressure plate are new. So i dont think those would have failed. but anythings possible. Oh, and my friend who installed the clutch said he did do it right.
Old 04-14-2015, 10:58 AM
stuart1's Avatar
stuart1
stuart1 is offline
If there is freeplay the hydraulics are not fully bled. Bleeding can be a real PITA.
Old 04-14-2015, 11:23 AM
zack987's Avatar
zack987
zack987 is offline
In your opinon, whats the best way of bleeding these things?
Old 04-14-2015, 12:24 PM
stuart1's Avatar
stuart1
stuart1 is offline
Keep pumping slowly until your leg falls off.
Quick Reply: 1991 F150 clutch wont disengage after replacement
