what spark plugs to use
Old 04-13-2015, 11:03 AM
ladelld33's Avatar
ladelld33
ladelld33 is offline
as you all know i have this 84 f150 that i swap in a 351w in with the GT40 heads from a 96-98 explorer. what spark plugs should i be running in this rig?? it's time for a tune up but i'm unsure on the plugs. i figure i'd better go ahead and do this while i'm doing this starter issue.
Old 04-13-2015, 11:21 AM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
If you are using GT40 heads from a 96-98 Explorer, you need to get spark plugs specified for those heads, not for your model truck.
I would recommend MOTORCRAFT plugs. Original equipment for a 1996 Ford Explorer 5.0 with GT40 heads is Motorcraft SP-432.
What ignition system are you using? Those plugs call for a gap of 0.054, but a 1996 Ford Explorer used a totally different ignition system than what came on your truck. If you are using a Duraspark II ignition, I would go with a 0.044 gap.
Old 04-13-2015, 06:33 PM
ladelld33's Avatar
ladelld33
Thanks for such a great response and with a part number! Im also gonna be replacing the ignition coil to so that gap might be okay but ill try it first!
Old 04-13-2015, 08:18 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,654 Likes on 1,337 Posts
Don't load down the old DSII ignition box with some super duper coil. People have not had good results from this, it heats up and shortens the life of the DSII box.
Old 04-14-2015, 09:23 AM
ladelld33's Avatar
ladelld33
ok thanks for the heads up cause i was on the way to getting a 45000v coil to put on it. but you guy have the experenice with these olsd girls. i guess i'll leave her alone and just get the right plugs...
SJMaye
1997 - 2003 F150
26
09-07-2017 03:16 PM
GreatNorthWoods
08-30-2012 10:27 AM
jamies460
20
07-10-2007 01:33 PM
BBF250
10-15-2005 01:48 PM
fordguy351w
09-08-2003 12:46 AM
Quick Reply: what spark plugs to use
