crossmember insulator
I don't remember anyone having used anything else. However, I do remember having eyeballed the insulators on my crossmember and realizing that the new ones I have for either the radiator or cab support are the same size. And, I mentioned that somewhere in some thread - but can't find it.
I can look today to see if I can recreate that realization and tell you which one might work. Will that help?
Most "insulators" and body mounts(including motor mounts) have a stud molded into the rubber when it's made. Running a bolt all the way through with a nut on the other side, whether it's rubber, a hockey puck, or whatever, defeats the purpose. The noise and vibration will transmit right through the bolt that is going all the way through.
I bought this set from JBG in 2012; they've apparently expanded their selection to include other parts; sleeves, etc.
Body Mount Bushings, Ford Truck, Black-Broncograveyard.com
Search "body mount" on their website and you can see it all --
big schott
09-03-2014 08:39 AM
oscajo
05-12-2014 06:19 PM
r2000f150
04-07-2008 06:47 AM
