91 f250 transmission problem
A tip when bleeding the clutch. Remove the rubber cup thing that goes into the reservoir. That way it holds more fluid. One pump, bleed, one pump, bleed, etc.
another thing is reverse bleeding. Pump fluid from the bottom up with a brake bleeder pump thing.
The system is so small that it doesn't take much to goof it up.
Sounds like you didn't fill the system before you installed it maybe? Either way it sounds like you still have a ton of air in there. You can try reverse bleeding with a hand held pump or just untamnd said, remove the cap and fill the res all the way and just keep pumping until you get good pedal.
MONAVIERONJON
20
11-18-2010 02:15 PM
just-n-time
08-07-2008 04:51 PM
Dr_Sin
11-22-2004 01:55 PM
