4 Questions for y'all
Evening, I have 4 questions for y'all.
1: Who makes the best all around repair manual for a 1993 f250 (see sig if more detail needed)?
2: How do I get window stickers and bumper stickers off?
3: What is the best way to bring rusty chrome back to life? (see pic, some is worse around the mirrors).
4: My engine causes the entire truck to vibrate, pretty darn well (351W + 5 speed manual ZF S5-42 manual I think). Its always been that way for as long as I can recall. But It felt like it got worse yesterday, could an engine mount be broken? Or????
on
I can help with the sticker removal.
Use: heat gun on low or a blow drier, flat razor scraper, a spray bottle with water.
Heat the sticker (that releases the glue on the sticker), use the razor scraper at a very slight angle, lift the sticker off with the scraper, use some water from the sprayer so you don't scratch the glass.
Best of luck.
Best of luck.
on
1. Ford.
2. Use a heat gun or hair dryer to peel the top vinyl layer off and then clean the glue off with GooGone.
3. If the chrome on these trucks is rusted the parts are done.. replace them.
4. That isn't normal. Do you get vibration when the truck is stationary and engine is running or just when the truck is moving?
Just when idling. Not while moving. Its worse after a trip of any distance, start up and let it idle not too bad but after a trip it gets worse.
Its not a shake the truck apart rattle, its mild but its there.
Ford Pick-ups and Bronco Repair Manual covering Ford full-size pick-ups F-100 thru F-350 and Bronco for 1980 thru 1996 and 1997 F-250HD and F-350 (Gasoline engines only)
Ill probably order that one since it gives me the basics of what I need to know.
The truck recently had a tune up with comp. checks, plugs, whole nine yards. Hence the reason I suggested a broken engine mount.
Its chrome.
