17yr old Female finds FREE 1986 46k Mile Bronco! - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Log In
1978 - 1996 Big Bronco SPONSORED BY:
Old 04-12-2015, 07:35 PM
Boss9F100's Avatar
Boss9F100 Boss9F100 is offline
Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.
The Teenager who is now 19 happens to be my daughter.
She was looking for a 4x4 (Ford) of some type and really wanted to buy a
92-96 F250 Diesel 4x4. Had to convince her its a money pit. After a few months of looking we found a 46k Mile 1986 Full Size Bronco
We went to look and were completely amazed how straight the body was and it was virtually rust free! (ok, a tad on the tailgate)
She has been saving her $$ to restore it.
Story is the person who bought it new was in the military of some sorts and shortly after purchase moved to Arizona, He took it to Germany where it saw very little use. Back to Az it came sitting in backyard where it sat for years.
He gave it to his son who shortly after signed up for military where he enlisted for 4yrs. When He came back home it would not start so it sat some more. So it sat the better part of 20yrs.
The Arizona sun killed the paint but the body was MINT!
I helped my Daughter haul it home where she first rebuild the entire fuel system. Removed and replaced the fuel tank (it had been left full) replaced the fuel pump and filter, flushed out the lines, replaced the fuel injectors and the fuel press regulator.
Changed oil, also there was no power inside. She bought shop manuals and studied the electrical system where she found a bad ground under dash.
It fired right up! Of course we did a compression check to make sure and it still pumped 175 psi which I was very surprised. Runs like a million bucks.
Then it sat for nearly 2 more years busy with school, some college and work along with saving $$. She did fire it up and run it once per month or so as learned how much work it was to get going with bad fuel.
Now that she has saved up some $$ let the work begin!
__________________
1966 F250 Deluxe Camper Special "RANGER" Special Paint
1965 F250 now gone bye bye . . Sad Face
1966 F100 powered by a 482" Dual Quad Side Oiler
1966 F100 Plain Jane AZ Grandpa Truck 352 3spd
1966 F250 Plain Jane Red/Red Long Bed 3.5L EcoBoost
1966 F600 Never Titled OR Registered Only 5388 Miles
Old 04-12-2015, 07:38 PM
Boss9F100's Avatar
The Bronco being a dark charcoal metallic that was pretty much burnt off by sun with a Red interior was most likely pretty sharp back in its day.
She has decided she wants to paint it BLACK!
Gotta find the pics . .
__________________
Old 04-12-2015, 07:41 PM
Boss9F100's Avatar
This was kinda as purchased but after a major cleanup because it sat so long.
We had already steam cleaned most of what was left of original paint off. Mostly primer showing here. She had started to remove the surface rust from hood and roof.
The gel coat on topper was gone down to strands of fiberglass.
We went junk~yarding and she was able to get a smokin' deal on a pair of seats, new top, fuel tank, some wiring and a spare styled steely type wheel.
Click the image to open in full size.
__________________
Old 04-12-2015, 07:45 PM
Boss9F100's Avatar
Here she is done scrubbing 1/2 of rust off roof. One will spot the hood in background.
__________________
Old 04-12-2015, 07:48 PM
Boss9F100's Avatar
After a LOT of scrubbing on hood and a bit of sanding she had it looking like this in short order . .
And yes, She made a trip to PPG paint store and picked up all the supplies needed for the paint job. Set her back a pretty penny. Close to 1500.00 so far in paint and materials!
__________________
Old 04-12-2015, 07:51 PM
Boss9F100's Avatar
A bit of elbow grease and a couple sprays of "Magic Soap" and she had the top looking like this. (It will be painted flat black)
__________________
Old 04-12-2015, 09:56 PM
1985 Bronco's Avatar
1985 Bronco 1985 Bronco is offline
1985 Bronco is starting off with a positive reputation.
That is a great find, and she does good work! We need more pics!
__________________
1985 Ford Bronco: 460, 3 inch lift, 35s
1949 Ford: 4 Door, flathead 6, three on the tree
1995 Ford Crown Vic Police Interceptor: Winter Beater
Build Thread:http://www.ford-trucks.com/forums/13...ld-thread.html
Old 04-13-2015, 02:23 AM
ZombieSlayer's Avatar
ZombieSlayer ZombieSlayer is offline
ZombieSlayer is gaining momentum as a positive member of FTE.ZombieSlayer is gaining momentum as a positive member of FTE.
Nice find She's doing a great job on the resto
__________________
Proud owner of a 1995 Bronco XLT, auto trans, 5.8L engine. 95% original.
Old 04-13-2015, 07:02 PM
Boss9F100's Avatar
When we first got it running it seemed like the water was not circulating so we pulled t-stat then the water pump.
This is what happens to antifreeze after sitting for so long. Good thing we did not run it long!
__________________
Old 04-13-2015, 07:06 PM
Boss9F100's Avatar
rear seat was like new. Someone removed the perfect front buckets so they needed replacing. Looking for a mint set of upholstery for the front buckets in case anyone can steer her in right direction.
A good cleaning prior to pushing it in garage
Also removed tailgate, hood, topper and trim
__________________
Old 04-13-2015, 07:09 PM
Boss9F100's Avatar
Pretty much started to sand to "feather" the primer but it was so dry it was pretty much sanded down to bare metal. Not much primer left. No paint remaining
Door glass was also removed
__________________
Old 04-13-2015, 07:50 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is online now
BaronVonAutomatc is gaining momentum as a positive member of FTE.
That water pump is gnarly. Do the block and head have the same crud in the water passages?
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
Old 04-13-2015, 08:33 PM
bigzirb's Avatar
bigzirb bigzirb is offline
bigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud ofbigzirb has much to be proud of
Your girl is doing some great work. She is putting lots of us guys to shame. Great job!!
__________________
2001 Excursion V10 4x4 Auto 151,000 miles 285/75/16 BFG AT's, stock rims
2nd trans cooler and spin on filter, converted to electric fan (increased MPG by 1.1mpg towing) Trans temp gauge, Volt gauge, and Vacuum gauge mounted in 3 gauge driver pillar pod, Custom Safari Rack, Full size spare on the rack, Mag light at driver door, LED interior lights.
1978 Bronco 460, NP435, BW1345, Dana 44HD/ Dana 60, 40's "project"
Old 04-13-2015, 08:59 PM
Boss9F100's Avatar
Quote:
No other issues with crud, only waterpump, although we did replace the radiator also.
Quote:
Been a bit of a lull for past week but hope to get back on it tomorrow evening.
I do not work on it or help unless she shows up.
I will take a few more pics of the progress to make it current.
She has spent a great deal on it already but sure helped to get the Bronco for free to start with. This way she will have a few bucks in it but everything will be new to start out with.
In typical Arizona fashion pretty much every weatherstrip on entire veh was dried out to the point it would just crumble when touched. Bought a complete body weatherstrip kit.
All the original chrome and trim was in pretty nice shape so she just buffed it up. Even buffed all the glass to make it look new.
After entire vehicle was sanded down we applied PPG DP74LF primer.
Then sanded it out again and re-applied as we did not get the blocking primer on within a week as mandated by PPG.
Its costing her some pretty big bucks for materials so we cannot afford to mess it up.
__________________
Old 04-13-2015, 09:01 PM
Boss9F100's Avatar
Just a note the way the masking paper is put on. Not really the correct way as any folds should be on the inside not the outside. Not that important for the primer but for sure a no no on final paint.
I kinda like to let her go on her own then explain what I consider a more proper way if need be.
Plan is to do a little change and paint the hood and topper flat black. the rest will be PPG Concept Black, the deepest black we could find. It will show every flaw but by looking so far the body will be every bit as good as it left the factory . .
__________________
Similar Threads
1986 300ci swapped to a 351w... colbudahas 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 10-25-2014 09:18 AM
Only 50psi out of new hpop Turbolover64 1994.5 - 1997 7.3L Power Stroke Diesel 26 02-02-2014 06:54 PM
Alien Interference? HeaVEEweight Excursion - King of SUVs 17 11-26-2013 08:01 PM
2003 escape. Bad fuel pump or emergency fuel shuttoff switch? go dart Escape & Escape Hybrid 1 06-17-2011 06:42 AM
Any Advice On How To Deal With Deadbeat Son-inlaw 18fan General NON-Automotive Conversation 53 07-27-2004 03:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
