Head gaskets on a .040 rebuild
Old 04-12-2015, 06:38 PM
Lakeside550's Avatar
Lakeside550
Lakeside550 is offline
Question Head gaskets on a .040 rebuild
Been searching all the forums (TDS, FTE, PSN) like mad and haven't came up with anything but a couple smart *** remarks.
I had my #8 cylinder scored pretty bad from a broken ring and had to go .040 over to clean it up.
Can OEM head gaskets be used when bored over that far?
I see PMM sells a .040 kit with factory head gaskets but it doesn't say if that's a special ford part number or what and it's sunday so I can't call :-p
Old 04-12-2015, 07:21 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
I do not remember having to have a special head gasket when going up to .06" on stock rebuilds when I built engines 25 years ago.
Old 04-12-2015, 07:32 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
I have never heard of special HG as it relates to bore size. I do know that the gasket cylinder holes are not perfectly round so you may have to file any edges that may hang over. Where you want to play close attention is how much is taken off the heads to get them flat. IIRC, the minimum is 4.74 head thickness (going off of memory), someone will correct me if I am wrong....
Old 04-12-2015, 07:42 PM
Lakeside550
Thanks for your input!
Good thing I have two brand new heads since mine were cracked!
The machine shop sent me home with a Victor Reinz "black diamond" head gasket and I've just read so many horror stories that I'm wanting to spend a few more bucks to get an OEM set - just want to make sure they're going to work!
Old 04-12-2015, 07:46 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
I would absolutely go OEM!
1990-f250
03-13-2021 04:44 PM
GB SISSON
05-07-2014 06:07 PM
chamblizi
03-31-2013 12:10 AM
K man
02-22-2007 08:03 PM
Reidicus
09-12-2006 07:46 PM
Quick Reply: Head gaskets on a .040 rebuild
