cat. conv. removal
You can remove the smog pimp/air system without any problems. Get a delete pulley for the pump itself, remove all hoses and plug any holes in exhaust hoses connected to
As mentioned above you can delete the air pump if you wish. It doesn't really have much drag, so there's not Very much to be gained by doing so. Some people prefer to just have it gone and clean up the space. The two tubes your referring to can be either left cut free (it's just air being sent through them) or piped into your new exhaust. Don't cap them off, the pressure build up will sputter through a valve up under the hood
Island Time
10-23-2014 09:49 PM
stngh8r
06-15-2006 02:35 PM
