Bronco stutter while acceleration. 3500-4000 rpm
Haha, maybe it should just stop yelling first and it won't stutter as much! Stuttering while yelling would be pretty embarrassing.
On a more serious note, I would first check spark plug wires and routing. Slight misfires from spark gap can be more noticeable at higher RPMS. Make sure your wires aren't touching the exhaust or grounding out anywhere else, and that they aren't sparking across each other. There are some diagrams floating around these forums on proper routing for the wires.
Also, check for engine codes! I'm assuming you probably don't have a 96 bronco, so you should look up the procedure for KOEO and KOER code checking. It's very easy and all you need is a paper clip and your truck keys.
ford racer 02
1978 - 1996 Big Bronco
11-19-2002 12:20 PM
