Need help ASAP
Just be careful not to smoke when you do that... Hopefully you are doing that into containers. Even though no one can use the fuel for anything other than a bonfire outside.
Changed the all the fuel filter, oil and filter when I got up this morning. I had to work afternoon so I didn't get to cut it open but I'm going to.
At half a mile gasoline made it to the hpfp. I agree with senix, bust open the engine and dfcm filters now that it has been driven, look inside the pleats and see if you find metal. If you do, best not to drive it.
I use a punch to carefully split open the seem on that sealed filter.
Also, make sure your tank is 100% back in place and sealed. Water seeping in there wouldn't be good either.
I thought those handles were for assembly as well. I didn't think it was a "plug" that could be removed and replaced. Something to use to hang up the fuel tanks on a line for a tech to grab and then use to help put the tank on the truck. I could be wrong as well...
Also, +1 to Senix and Kper05.
I broke open the filter this morning, opened the pleats up and didn't see any metal of any kind. Even went as far as taking the magnifying glass to look. I'm going to run it awhile and change them out again. When we pulled the sending unit out it was all smooth on the inside and that's what had me curious as to what they where for. I though maybe to handle the tank during assembly but wasn't sure
With my truck, two things that I always check and double check.
Glad this worked out well for you.
- I am the only person that fills my tank. When filling, I check and double check that diesel is the only thing going in the tank. I don't pull the little handle until I am certain that the correct fuel is going into the tank. For me, I worry when filling up my wife's car. I'm more likely to put Diesel into her car than Gas into my truck. I never use the shared pumps. All pumps where I fuel up are diesel only.
- When filling my DEF tank, I never do this if I am in a hurry. Take my time and insure DEF is not going into the fuel tank.
SMB
16
01-13-2005 10:49 PM
