1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
4x4
Old 04-12-2015, 11:58 AM
bobkonaben's Avatar
bobkonaben
bobkonaben is offline
Smile 4x4
I have a 2003 250SD 4x4 and I was just told that I should run my truck in 4 wheel drive every now and then to keep the gears lubed.I hav'nt driven it in 4 wheel drive since I purchased it a year ago. I do not go off road at all, just tow my bumper pull rv and drive it around town. Thanks as always you guys are great. Bob
Old 04-12-2015, 12:02 PM
jetjockey99's Avatar
jetjockey99
jetjockey99 is offline
That is good advice. By doing so you keep everything lubed in the front axle, otherwise the gear oil just lays in the bottom of the housing. I run mine at least once a month in warm weather, in the winter time my front hubs are locked in 99% of the time so the axle is always turning.
Old 04-12-2015, 12:42 PM
Psyclopse's Avatar
Psyclopse
Psyclopse is offline
Not only the lube issue, but if you have ESOF, it's probably a good idea so that the actuator gets some use.
hale88
1983 - 2012 Ranger & B-Series
06-09-2019 10:22 PM
CR3999!
20
10-18-2015 05:17 PM
fernando007
12-22-2009 12:52 PM
Headstone
12-23-2004 06:05 PM
DW2455
1978 - 1996 Big Bronco
08-31-2003 08:42 PM
Quick Reply: 4x4
