DP Tuner F5 Stock
DP Tuner F5 Stock
Can anyone tell me how to set the F5 to stock. According to what i have written down from the previous owner, my F5 has 80 HP tow, 60 HP econ, 80 HP econ, Decel, and Hi-Idle. I am having some issues trying to read PERDEL readings in AE ( they are all 0.00) and wanted to try to do it in stock setting? I thought about pulling the tuner off of the PCM to test but i also have Casserly Stage 1 single shot injectors and read that i must have a tune to run those?
Typically stock is position 1. Not sure about the F5 but I would assume position 0 is no-start.
What some here have done is; They will have the PCM flashed to run the singe shots. That way if a problem develops with the chip, it can be removed and you will still have a reliable truck. The chip gives you various settings other than just stock.
But you can have the the chip set up to run single shots with out having the PCM flashed. However if you remove the chip the truck will run, just not well.
Received 3,107 Likes
on
I got the tunes from DP Tuner and have 80 tow, 60 Econ, 80 Econ, Decel, high Idle. I wanted to know if I disconnected the tuner would it be stock? Maybe the PCM is tuned to stock or would it be something different? I'm just trying to get perdel readings with AE. I don't thing my truck would be 0.00 on all cylinders but I could be wrong.
Surprising. DP Offers a Stock Tune for no additional charge when you order it.
I would remove the chip.
