code po299 HELP
code po299 HELP
hi everyone i had a very bad day yesterday after loading my families atvs on our trailer and heading 40 miles away the 6.0 let me down. the check engine light was on about a month ago but the truck was running perfectly so i unhooked the batteries and reset it and the cel had not been back on until the start of our journey yesterday. the cel came on and the turbo barked and then every time i hit the throttle i had no boost till about 2500 rpm then the boost would go up to 30-33 psi only going 60 mph. so after making it to the trails and making it home i took it to advanced auto to read the cel codes and they pulled the po299 underboost code. now i know that this has been brought up many times but i cant find any where the truck has been over boosting like mine was. and also i did check all the boots and they all seem to be fine.
i really don't want to take it to ford until i know some of the cause because the truck isn't under warranty
also only mods to the truck are mbrp 4 inch turbo back exhaust and afe stage 2 cai
You need something to watch live data from the pcm. You need to watch vgt and see what is going on. Check the map sensor hose for cracks and make sure the nipple on the intake is clear, push some weed eater line through it. Do the same for the ebp sensor, clean the tube and make sure it is clear. Last clean the turbo veins. Live data will help narrow down what is going oon.
FWIW, I cleaned out the EGR, EBP and MAP tube. No change.
I am not as far along as you, other than a cold start problem, truck runs normally. I am looking at the Garrett Powermax from Sinister. $1089 then it is just labor to install.
Thought I remembered the Ford remanufactered units were about twice that.
Depending on where the vanes stick open will help determine the psi. Mine too ran with more psi but pulled a P0299 underboost too.
Once determined it was a stuck unison ring and fixed, I had less immediate raw power but instead, a more consistent pull.
Just because your turbo spools up over 26 psi doesn't necessarily mean it an overboost condition code.
