Axle Swap 2006 F250
Axle Swap 2006 F250
Hi all,
My pinion bearings went bad on my 10.5 Sterling after some idiot didn't set preload correctly. Thinking of swapping a low mileage 2011 rear with the e-locker from a donor.
I know the speed sensor is different, but does my truck have ABS in the rear? Does the speed sensor also serve as the abs?
Anything I should watch out for besides the obvious like ratios? Is the yoke the same pattern?
Truck is a 2006 F250 FX4 Crew with short bed.
Thanks
Thanks
Joe Bleaux
1999 to 2016 Super Duty
10-18-2016 03:13 PM
