help with rear drum brakes on 1966 f600
I don't have no reason can afford to buy a torque wrench to go to 500 lbs , mine goes to ether 250 or 300 lbs, so I am going to go to my max setting then and a little more by feel with a cheater bar , and hopefully it'll work, back when I was a kid working on my old ford small trucks, i never really ever used torque wrench, but I'm older now and should know better, i am on disability because of back and neck injuries, i am trying to make a little extra and be able to pull my rv to see family in other states, thank you all for your help
I thought those numbers looked high for wheel bearings, but I find similar numbers with a quick look at an Eaton PDF for some axle, the first thing I pulled up. You should be able to search out the specific shop manual for your axle if you didn't already. Eaton has tons of them on line.
Remember the torque should be applied with the hub turning. You want everything moving as it's tightened.
Good luck with it. Don't forget the lock washer....
Almost all medium duty and heavy duty trucks have L/H studs on driver side R/H on passenger side
Theory being as the wheel rotates the lug nut will tighten not loosen if not properly torqued
I need help 68 n600 needs new drums and all brake parts and seals!
Hey this sounds like what I'm just now getting into on my 68 n600.
Maybe you can help me!
In your search for parts did you get a contact for new drums? I need 2 bad.
Where did you find most of your parts?
I'm starting with Napa or that going to be a waste of time?
Check out my thread. I think you can search by my, imjstsitner.
Thanks for any parts direction you can give me.
I made this years ago. Heavy wall tubing with a 1-1/2" socket welded on on end and budd socket on the other. I welded a 1-1/2" solid bar through the tubing. Put a cheater bar as long as you need on it. 6' usually works, although one time i resorted to a 10' bar. That time each lug nut broke free with a sound like a gun shot and you could see the rust and debris like smoke. I figured either the lug nut would loosen or the stud would break. Either way the wheel is off. Works great at pick-a-part where there are no air tools.
The following users liked this post:
gravdigr
07-06-2015 02:40 PM
Jason Neuman
12-13-2012 02:15 AM
gearhead351
05-01-2007 03:09 PM
