4R100 failure
4R100 failure
On my way home yesterday, about a mile out, I back off the gas to go around a curve and the transmission SLAMS hard into third gear. Like i got rear ended hard. As I pull into the neighbor hood the engine stalls and I pop it into neutral and restart it while still rolling. Put it back into gear and, against my will, gradually roll to a stop. I rev the engine, and go no where. I get out and look and there is a puddle of transfluid under the truck. I got a quick tow home and and transfluid continues to puddle underneath the truck. I tried to find the leak with flashlight, but I had no luck. I tried again today since I have daylight and I cannot get any fluid to leak out. The dip stick shows I have plenty of fluid, but there was atleast a quart on the ground where I initially broke down and a very obvious trail leading to said spot. There was atleast another quart in my drive way after only 2 minutes of sitting yesterday. So i know I lost a lot of fluid. I added 6 quarts of fluid and I'm still not getting any leak anywhere.
There is transfluid splattered inside the lower portion of the passenger side wheel well, and a lot of fluid on a small section of the passenger side exhaust manifold right before it bolts to the turbo up pipe. The codes that came up with AE was for trans fluid over temp. The temp reading I got was 173 with AE.
What do I do next?
The truck is an 03 4x4, stage 2 injectors, swamps performance IDM, cold air intake, 4" exhaust, Banks quick spool turbine housing and compressor wheel, and DP-Tuner.
What do I do next?
ok, so after adding a total of 10 quarts I have finally replicated the leak. It is coming from the top on the back drivers side of the transmission. I have no clue how transfuid got to the places in the pics i posted before, but i have checked and rechecked, it is transmission fluid in the pictures.
So what is in that area of the transmission, and can I get to it with out dropping the tranny? The fluid is pouring out in a steady stream like I'm just pouring fluid out of the bottle.
ok, the fluid is coming from an open hose on top of the back of the transmission. I tried to follow it up towards the front of the transmission, but i lose sight of it about half way up. It looks like a vent hose. It is not the vent hose for the transfer case. I can see that one just fine. Can any one tell me what this hose is?
edited:
ok, so I've managed to trace this hose back to a fitting on top of the transmission by the bell housing. Why would i be dumping transfuid out of the vent tube? I put the truck into gear, and the RPM's drop down a bit as normal, but the truck wont go anywhere. I checked the shift solenoids with AE and solenoid 1 is constant on, and shift solenoid 2 comes on when i shift it 2nd gear. solenoid 3 stays off. Is there anything else I can check?
It's been a while but I finally got time to get back to the truck. I've got 60 PSI at idle while in park. I've swapped a few transmissions and I have never seen fluid this dark. It almost looks like motor oil. I changed the trans fluid and filter when I bought the truck 50,000 miles ago. I've check the fluid periodically and it has always been good.
