Bronco payload and tow capacity - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 07-26-2003, 04:53 AM
Cheap Monster Cheap Monster is offline
Cheap Monster is starting off with a positive reputation.
I got an 87 302 Eddie Bauer Bronco. Just curious what the advertised tow capacity and payload is for it. I did a search and couldn't find anything. Thank you much.
Old 07-26-2003, 02:41 PM
DeGideo DeGideo is offline
DeGideo is starting off with a positive reputation.
You forgot to mention what transmission, and axle gearing your 302-powered Bronco EB has, but here is what I found out from the 1987 fullsize Bronco Owner's Manual : 302/ 5-speed/3.55:1 ratio(s) : maximum suggested trailer towing weight is listed as 4,000lbs. For the 302/automatics(C-6 & AOD)/3.55:1 maximum suggested trailer towing weight is listed as 7,700 lbs. For the 302/AOD/4.10:1 combination, suggested maximum trailer towing weight is listed as 8,000 lbs.
Old 07-26-2003, 08:09 PM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
Are those #s close to or the same for 82 models. Mine has a 302, C6 tranny and 3.55 gears.
I usually haul a 1948 for 8N tractor w/ shredder, on a 16ft. tandem axle trailer that weghs about 1500 pounds or so.
I shredd fields on my spare time for a little exra money.
Bye the way, Fords never die, my tractor is living proof.
Old 07-27-2003, 11:14 AM
I'm not sure about the 1982 Bronco's tow ratings. Stock, I don't think the 302-2V would have the same towing capacities as the later EFI302s. I don't have a '82 Bronco Owner's Manual, but that's where you'd find the towing capacities for them. You can probably still buy one through Helm,Inc. (www.helminc.com),or pick up a used one on ebay. In the 1982 Bronco factory brochure, it lists a HD Trailer Towing Package, but doesn't list the equipment included in it.
Payload and tow capacity? steuspeed Ranchero & 1961 - 1967 Econoline 1 07-29-2016 05:06 PM
Payload and camper package Onefortheroad 2017 Super Duty 8 06-27-2016 03:33 PM
MaxTow with HD Payload vs. Tow Package with HD Payload Ottawasteve 2015+ F150 3 03-20-2015 11:28 AM
95 F450 (SuperDuty) Payload Capacity? POLOLOUS 1994.5 - 1997 7.3L Power Stroke Diesel 0 10-08-2007 10:48 AM
payload, towing and fuel capacities of 2004 F150 jalbs 2004 - 2008 F150 1 01-08-2003 01:39 PM
Tags
1978, 1996, 302, 302v, 87, bronco, c6, cap, capacity, f100, payload, payloadon, rating, tow, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
