Looking for a Rebuilt Damper '64 223
It seems to be a hard part to find. I'm wondering if any of you fine Ford folks has a damper for a 1964 F100 with a 223. It's my only vehicle so I can't pull mine and send it off to be rebuilt. I tried the Damper Doctor but his line is always busy when I call and no response to my emails. I'm really close to the Expo center here in Portland where the auto swap meet is happening so I can easily make it over there if you happen to be a vendor there!
Going to be tough to find a single-year only balancer.
There is another firm that rebuilds balancers - http://www.damperdudes.net no idea how reputable they are but give them a call.
Might try contacting http://www.flashbackf100s.com for a used one and find someone to rebuild.
No, what I'm getting at is try to find a used one from Flashback, say. Or whoever. Then, send that one off to be rebuilt. This will minimize down time. Make sure you have a puller and an installer. A long grade five or better bolt and a big stack of washers will work for installation. Avoid hammering or pounding on the crankshaft to install, imo.
Even if you were to find NOS damper it may have deteriorated sitting on the shelf. Ozone attacks rubber. And any used one you find, may be worse than what's on there now. Maybe not for you, but (for me anyway) changing dampers is kind of a pain in the ***. So I only want to do it once.
That was my thought too, find one to send off for rebuilding to save time. I actually tried to edit this post to remove "rebuilt" but couldn't change the title.
I have a connection who will loan me the needed tools and might help too, just need the part. I'm wondering if I should change out the chain while I'm down there too.
woodhd
11-25-2014 11:29 AM
