Go Back   Ford Truck Enthusiasts Forums > Marketplace > Ford Truck Parts for Sale
Sign in using an external account
Register Forgot Password?
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Old 04-10-2015, 12:37 PM
Connecticut Calvin Connecticut Calvin is offline
Connecticut Calvin is gaining momentum as a positive member of FTE.
5 Lug 20" Antique Steel Dually Rims
Category: Wheels & Tires
Price: $100
Private or Vendor Listing: Private Listing
Location (State): CT
Item Condition: Used
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
Part fits:: older-1947, 1948-1960, 1961-1966
I have 4 extremely rare vintage steel 5 lug (8" pattern) 20" budd style dually rims coming off my 1956 Ford F500. Though they have surface rust they are completely useable (inspected by a well known local truck tire center). There are tires mounted but they are completely shot and will be removed before purchase. The rims will fit either 7.50X20 or 8.25X20 tube type tires. These are NOT "widow maker" Firestone RH-5 rims. Two have the continuous lock-rings and two have the split lock-rings. I'm asking $100 each firm.
These can be shipped via freight through Pak-Mail not far from my home here in Simsbury, Connecticut.
Old 05-16-2015, 07:00 PM
mokandshuk's Avatar
mokandshuk mokandshuk is offline
mokandshuk is starting off with a positive reputation.
Is there any way you could take a picture of one. I am trying to see if it is the same thing I have on my truck now?
Click the image to open in full size.
Old 05-16-2015, 08:46 PM
Yes. Same exact sized rims. But you have Firestone RH-5 "widowmaker" rims as they're dubbed. They are identified by the raised band on the inside of the rim. Mine will fit your truck but are the "safer" kind that most truck tire shops will work on. I'm on my iPhone at the moment...I'll switch over to another device for a picture...hold up.
Old 05-16-2015, 08:49 PM
Budd style 5 lug 20" steel antique truck wheel.
Old 05-18-2015, 08:33 AM
mokandshuk's Avatar
It looks like they would be a perfect size replacement for what I have on there now. I am based in Oswego NY so you are only a 4 hour and 15 minute drive away. I just need to check first today to see what exact rear end is on the truck now, to make sure I can get brake parts for it.
Old 05-18-2015, 10:56 AM
I'll send you a PM with my contact information.
Old 05-19-2015, 10:52 PM
mokandshuk's Avatar
Thanks Cal! I will shoot you a text tomorrow. I did have one last ? When I look at the pic of your rim, the centerpiece just appears smaller than what I see on my rear end/axle. Can you take a look at this and see if it will fit the opening on your rims?
Also my rim seems to be concave as if you are looking down at a bowl, but yours seem to be convex where it looks like a bowl flipped over/the reverse. I am hoping those fit on the duals?
Old 05-20-2015, 06:03 AM
Morning! Okay - so the dually rims fit on the back by turning the only flat faces on each rim into one another to make them "duals." They are then fastened to the axle with a dual purpose lug nut/bolt system. You can see what I mean on the rear wheels of your 250 now. Those same rims would be turned just as you see in my picture above to mount to the front axle. In other words you'll be looking into the "bowl" on the outter wheel of the rear duallies. The "bowl" is turned around facing inwards towards the truck and wraps around the brake drum on the front. Your tires are 20" right? The measurements should be like '7.50-20' or '8.25-20' . I can't see a tire size in the picture.
My center hole looks smaller because the wheel in my picture goes onto the outside of the hub up front where as the hub passes through the center of the wheel on the backs. But they're the same.
Old 05-20-2015, 09:49 AM
I see in the first picture with the mud on the sidewall that your wheels are indeed 7.50-20s. My wheels will definitely fit your truck.
Here is a picture of the inner hole diameter (same as yours) and the wheel upside down to show the "bowl" you were referring to.
Inner hole diameter...
Wheel as would be mounted on the outside of the dual rears...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
6x20 Rims for 1956 F500 Connecticut Calvin WTB - Parts & other 1 02-19-2015 09:04 AM
Found a bunch of 5 and 6 lug 20" wheels...BUT... Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-16-2015 05:19 PM
Widowmaker Clarification Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 12-21-2014 03:34 PM
Where the heck do I find 20" budd style rims with a lock ring? bmoran4 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 09-22-2010 08:47 PM
I'm Screwed now reamer 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 02-14-2005 01:36 PM
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
