To build a Flareside (with pics) - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Log In
Old 04-10-2015, 11:02 AM
SCFlareside SCFlareside is offline
SCFlareside is starting off with a positive reputation.
Hello all, new to the community - have already learned a lot from the forum. About a year ago I ran into a guy at a local gas station with a really clean '82 F150, and I realized how long it had been since seeing a good example of one locally.
That truck stuck with me, and I began to think about watching for "the right one". Something that I could wrench on with my (basic) abilities, maybe use as a weekend driver / Lowes truck and slowly bring back to great shape.
Started looking at Flaresides too, and appreciating the last of the "old" Flareside look on the 80-87s. Problem was scarcity of course.
Finally, I came across a Flareside parts truck with a bed in great shape. Owned by a young man about 30 minutes away, it was an '81 F100 with a cab that was toast... but it had been restored about 37k miles before the accident. Went to see it, and not only was the bed really clean, the interior was nice with a great dash pad, great bumpers front and rear... and a 300 CI six that fired right up and purred with 37k miles on it. The tailgate wasn't available, so am in the hunt for one (anyone?)
Click the image to open in full size.
Now, my very understanding wife had already bought into the idea of a weekend truck, provided it looked ok in the driveway. This parts truck didn't fit that bill. It needed to be bought, so I struck a deal with my local garage for it to live there for a while... and the truck was mine.
Unloading it from the rollback (above):
Prior owner was awesome and threw in a few other bits - the Flareside cap had come with the truck when he bought it, and while I don't have plans for it, it's good protection for the wood floor and other parts storage. Had an OE cassette player, and side steps to boot.
The truck had been in a slow roll, so lost the hood, drivers fender, and the cab was crushed on the top left. A little damage was done to both flareside fenders, almost identical damage on each side (probably from flexing? - see below)
So now the hunt was on for the right truck to go with it. I definitely wanted a 4x4, but now didn't need to worry about the bed. I settled on an '85 F150 that was fairly local, and owned by a mechanic. It was his daily driver which I liked, rather than buying something sitting in a field someplace. He had installed the 302 HO with EFI from a 1995 F150, along with swapping in it's '95 styleside bed. it was originally a 300 CI six truck, but still had the granny low 4 speed it came with. New brakes, bearings, U joints, belts, clutch, water pump, cap/rotor/plugs and wires.
On the downside, it still needed some things: Nice frame and cab corners, but a rust through hole at the back of the floor pan (drivers side). Distributor was wobbling and the truck was running a bit rough. O2 sensor was damaged (laying on the frame). Water pump new but needs the right bolts... and the Fuel Pressure Regulator was bypassed. Gauges inoperative except Alt and Oil pressure.
The truck had a red interior that was really well worn BUT the parts truck had... wait for it... a red interior. I figured that I could swap on the correct bed and sell the '95 bed to recoup a few hundred bucks.
Other details I liked - he already had the "right" wheels on the truck, and a set of good BFG A/Ts on the front which meant I only need two for the rear eventually. My goal is to go back to the look that the truck would have had in '85 / '86 when I was in High School, but upgraded just a bit.
Thought about it for a week, and a deal was struck! Here it is sitting out front:
And so it begins.
My first goal is to get the truck happy and running right without breaking the budget... and then to get it pretty, so it can sit in the driveway while I putter with the small stuff. Starting with Distributor and Coil, and O2 sensor, then hopefully bed swap and prepping for paint.
Old 04-10-2015, 11:06 AM
Things I forgot to mention:
F150 needs front fenders as well (rust on the arches). It also has dual tanks, which makes for a good but interesting dilemma with the Flareside bed. I'd like to keep them, and got some input from the community already in another thread (thanks lads!). Will probably run the filler neck to a flush mount filler in the bed floor, or possibly let it live in the fender well.
Old 04-10-2015, 11:07 AM
billabongboy73's Avatar
billabongboy73 billabongboy73 is offline
billabongboy73 is starting off with a positive reputation.
countryboy82
Welcome to the FTE forum, so are you keeping both or just going for one nice solid truck?
__________________
Chris
1981 Ford F-100 SLB, 302, AOD - Work In Progress
1989 Ford Bronco, 351W, AOD - Left in Texas
2010 F150 FX4 5.4 SCREW - Daily Driver
Old 04-10-2015, 11:09 AM
1986F150six 1986F150six is offline
1986F150six is a name known to all1986F150six is a name known to all1986F150six is a name known to all1986F150six is a name known to all1986F150six is a name known to all1986F150six is a name known to all
Great project! Keep sharing with us.
__________________
1986 F150 4.9L 4 speed manual O.D. Duraspark conversion with Carter YF
Old 04-10-2015, 11:34 AM
Thanks guys! Once I get the '85 up and running, not sure what I'll do with the '81 parts truck. I'm removing the bed / interior and some other bits, but it has the great motor with a clear title (wreck was never reported).
- Could sell the '81 F100 with the good motor and trans (4 speed OD) / clear title, OR
- Could look for a good F100 / F150 that needs a 300 CI six and put the motor in it... but that would be another project and then I'd have ANOTHER truck.
In the end, I just want to end up with one
Old 04-10-2015, 07:24 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
I have a Brand new tailgate in the box from a project from 20 years ago if you are interested
__________________
Looking for Blue 40-20-40 seats. PM me !!!
Old 04-10-2015, 07:57 PM
Tailgate
Interested! As a new member I can't PM but will message you on your visitor page
Old 04-11-2015, 10:24 PM
Interior
Spent a bit of time pulling the interior out of the F100. Man what fun working on a simple vehicle again! Really happy about the dash, a bit of discoloration on the edges but very solid. Cleaned up well, and happily soaked in a few coats of ArmorAll:
Old 04-11-2015, 10:28 PM
Seat
Here's the seat after it's first cleaning. Prior owner had pulled the back window out of the F100 for his other truck, and am not sure how long it sat that way. I think it was just for a few months. I was worried about moisture on the seat and interior but it doesn't seem bad. I haven't taken the cover off yet though.
There's one stain on the passenger side that you can see, and a very small tear in the fabric part. Tear is only about a half inch long, need to figure out how to stop it from expanding though. Sorry the pics are a bit grainy
The door cards are in great shape too, all must have been redone when the F100 was rebuilt before the wreck. The F150 will have the interior pulled and replaced with these. For now they'll sit in the garage until the other work's done though
Old 04-12-2015, 07:27 AM
maytag906's Avatar
maytag906 maytag906 is offline
maytag906 is starting off with a positive reputation.
Nice project! It's funny that the 85 was owned by a mechanic, and had all those mechanical issue's.
__________________
One foot on the brake, and one foot on the pedal....
Old 04-12-2015, 10:42 AM
I know, I think he was doing what he could, my sense is that the distributor happened after he decided to sell and he came down on the price. Still the truck drives well and tracks great, you can tell it wants to run
Old 04-21-2015, 09:08 PM
Moving the ball forward
Some of the parts are starting to show up at the front door thanks to USPS - or, I'm lugging them into the garage. .
First off the distributor - went with an MSD Pro Billet ready to run version (again this is for a 1995 5.0 motor)... along with a coil.
Just as I was about to go out and do the install this weekend, I watched a video online where a guy had the oil pump drive shaft fall out and down into the pan. NOT what I'd like to have happen in my driveway, given my ability level. I'm thinking about letting the lads at my friendly neighborhood shop do the dizzy install... besides I don't have a timing light. Yeah, that's it. A timing light. Call me a chicken and talk me into doing it guys
In the end I got distracted with some other things this weekend (see below):
Old 04-21-2015, 09:20 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
ctubutis ctubutis ctubutis
This kind of work is most easily done with a timing light. *hint* *hint* *hint*
__________________
About the logo
Microsoft is writing software for the kind of people who'd type google into the google search bar to get to google.
http://news.slashdot.org/comments.pl...7&cid=47003415
Old 04-21-2015, 09:37 PM
Anyone have good recommendations for ECU box?
Here's what you see looking into the passenger front fenderwell - at least the O2 sensor's factory connector is intact though. The sensor itself was still sitting in the bung at the H pipe, but the wire was broken off. Easy fix!
We got a bunch of rain this weekend - knew it was coming, so accelerated all the lawn chores outside on Saturday. Didn't leave much time to work on the truck, but did get a few things done.
The PO had completed the engine swap but there were still some cleanup items left. One big one was the ECU which was sitting on the drivers side fender and needed some kind of box built for it. I was thinking of an ammo can, but the two or three I have are all a bit too small. I may need to go with a larger size, or buy a box that's purpose built for it. I don't want to go to the trouble of moving it into the cab, but would like to build a weatherproof box in the engine compartment. If anyone has good ideas let me know!
This weekend on Sunday, we had a bunch of heavy rain. I popped the hood and this sight of a wet ECU greeted me
Decided i needed to do something right NOW... so I took a plastic case that I had on hand, stripped it of it's innards and cut a hole for the wiring harness. I put heavy duty velcro on the bottom of the case, and the fender to keep it in place. I lined the inside of the case with a bit of foam, drilled a few holes in the bottom for drainage, and hit it with some paint. Not pretty and not what I want for a permanent home, but at least now it will stay dry, and in place.
Pic below is closer than the one above - case is just big enough to fit the ECU and the first four inches of wiring. I also cleaned up some other areas of the engine bay with wire loom.
Old 04-21-2015, 09:40 PM
Ctubutis sealed the deal - letting the shop do the distributor I get the hint!
Similar Threads
Rare: 80-86 Factory Flareside Cap SCFlareside Ford Truck Parts for Sale 4 08-29-2015 06:19 PM
My '76 dent side build (with a lot of pictures) JHalvorsen 1973 - 1979 F-100 & Larger F-Series Trucks 18 08-07-2015 12:58 AM
Professional fix or do it yourself type job Paul81 Appearance & Dress-Up 1 07-22-2015 06:01 PM
1979 F 350 Ranger 4x4 Hurk76 Vehicles for Sale 3 02-09-2015 07:18 PM
Need AT Column Collar 1980 F100 Golden_F100 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-08-2014 06:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
