Battery cables '99 SD
My battery cables on my '99 SD have had the ends replaced with those cheapo bolt on cable ends. The ground cable end has 2 spit washers, to take up the slack, I think they may have used two positive cable ends. I need to remedy that.
I also noticed that there are 2 cables attached to each cable end, both are large cables.
Is that stock, to have two cables?
snaponprofile
05-07-2011 08:43 PM
