Can 2000 F450 Rear Axle Assembly be Replaced with Later Axles?
Hello,
I have a 2000 F450, 7.3, 4x4, dually, VIN 1FDXF47F0YEA44380, with 30k miles, That needs a new rear axle - hub retainer threads on axle housing are stripped (nut welded on by previous owner). This axle is a case ID F81A-4001-BK, 4.88 ratio, 11.25 ring gear, with a 41.5" spring center. I have heard that the '99-'02 axles had issues until Ford switched over to the later square housed axles in 2002 or 2003 (Dana 110, I think). Does anyone know if it is possible to adapt these later (2002- 2004) axles onto a 2000 F450? And if so, what would be involved?
I really appreciate any help on this!
Thanks a bunch!
Thanks a bunch!
Looking up your part on car-part.com only pulls up results for 1999 and 2000. That site is pretty good at showing you what will work WITHOUT modification.
Of course, that doesn't mean a later axle can't be used with modification or extra parts- it just means it likely isn't a simple out-in proposition.
If I were a betting man, I'd guess the only real difference is probably the U-bolts and plate. BUT- that's just my best guess. I'd go look at one and see first-hand what the differences are.
Bootlegger's Deluxe
06-17-2018 11:45 PM
